20 Most Recent Pioneer DEH-P8500MP CD Player Questions & Answers
Need to turn it off to tow vehicle behind motor
Usually, On a pioneer stereo, the button that you press to change sources (Tuner, CD, etc etc).. if you hold it in, the unit will turn off.
Look for a button that says Power, or PWR near it with a Square and little line coming from the square, that means you need to hold that button to perform that function. Hope this helps.
5/9/2010 5:24:27 AM • Pioneer... • Answered on May 09, 2010
CANNO TTURN POWER ON FOR THE deh-p8500MP
The ribbon cable under the radio face is broken
you can get one from pioneer parts or oemautosound.com
good luck
4/1/2010 12:17:02 AM • Pioneer... • Answered on Apr 01, 2010
2answers
Just wondering if Pioneer DEH-P4000UB cd player
no it does not have built in bluetooth but you can get a optional bluetooth kit Pioneer CD-BTB200
1/20/2010 4:13:49 AM • Pioneer... • Answered on Jan 20, 2010
PIONEER DEH-P8500MP car stereo system suddenly
the flexible cable between the lower face and the main power board is probably bad.
9/21/2009 10:45:06 PM • Pioneer... • Answered on Sep 21, 2009
The face opens up but there it doesnt light up or play music
You need the ribbon cable kit that pioneer sels to repair it. Kit is sometimes on ebay for around 25.00. They usually don't include the second ribbon cable and you DO need that too. You can go to http://parts.pioneerelectronics.com or call 1.800.228.7221 Monday - Friday: 7:00am - 4:30pm PST Closed on Saturdays, Sundays and major holidays. tell them you want the kit that comes with a new bezel and the left hand (smaller) ribbon cable also. They should be able to look up part #'s and give you a price right there. You will then need to have them installed or install them yourself. It's not impossible, bit it's not that easy either. If you are good with small mechanisms, and delicate things, you will be ok. I think the kit even comes with instructions. You will need to remove the unit from the car. REplacing both the cables will bring your unit back to life. It retailed for over 600$ in it's day. A nice radio for sure. Kinda like a transformer. ;-0
6/13/2009 10:44:07 AM • Pioneer... • Answered on Jun 13, 2009
2answers
Unit powers down when motorized face opens
i also have had this unit for over four years. the exact same thing just happened to me yesterday. i was thinking maybe it is the motor that opens the face. has anyone found an exact solution for this problem yet?
2/14/2009 10:09:42 PM • Pioneer... • Answered on Feb 14, 2009
I cant find the fuse
hi there should be a fuse in the power loom. there are no fuses on the unit itself. sounds like you have a faulty unit
mark
www.blueice-electronics.co.uk
11/25/2008 4:53:40 PM • Pioneer... • Answered on Nov 25, 2008
2answers
Clock!!!!
For most Pioneer single CD players, you can set the clock using the following steps: 1.Press and hold the SOURCE button until the unit shuts off. 2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. 3.Press the left or right arrow to select the segment of time you wish to adjust. 4.Press the up or down arrows to increase or decrease the numbers in the blinking segment. 5.Once the clock is set correctly, press the SOURCE button to exit.
2/20/2008 1:59:08 AM • Pioneer... • Answered on Feb 20, 2008
Unit opens and closes on its own
I think I got the second half of the solution for this problem. Please look at post "Unit powers down when motorized face opens" for a solution. Seems like we need to buy the ribbon that connects to the face plate to fix this problem.
2/8/2008 4:34:45 PM • Pioneer... • Answered on Feb 08, 2008
Opening
the flexible pcb in the unit is broken and you will need to replace it, the pioneer part number for the replacement is CNP 6869 this is a replacement kit
12/7/2007 5:14:31 PM • Pioneer... • Answered on Dec 07, 2007
Pioneer xv-htd540 5 disc dvd/cd changer surround sound system TIMER LIGHT KEEPS ON BLINKING
The timer light constantly blinking on a Pioneer XV-HTD540 5 disc DVD/CD changer surround sound system could indicate a few different issues. To resolve this issue, you can try the following steps:
  1. Check the connections: Make sure that all cables are securely connected to the system, including the power cable, audio cables, and any other cables that may be required for your setup.
  2. Reset the system: Unplug the system from the power source, wait for a few seconds, and then plug it back in. This can sometimes resolve any issues that may be causing the timer light to blink.
  3. Check the discs: If you have any discs in the changer, remove them and try turning the system on without them. Sometimes, a dirty or damaged disc can cause the timer light to blink.
  4. Perform a factory reset: If the above steps do not resolve the issue, a factory reset of the Pioneer XV-HTD540 may be necessary. This will restore the unit to its original settings and resolve any software-related issues.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service. It's important to follow the manufacturer's instructions and safety guidelines when attempting to repair or troubleshoot your system to avoid damaging the unit or causing potential harm.
1/29/2023 12:40:44 PM • Pioneer Car... • Answered 3 days ago
Pioneer stereo - power converter
¿Hay un adaptador que pueda comprar o forzar? para cortar y empalmar cables
1/6/2023 2:34:03 AM • Pioneer Car... • Answered on Jan 06, 2023
Source changes itself on my pioneer AVH-X491BHS
Hi there! It sounds like you're having some issues with your Pioneer stereo. For the first issue, it could be due to a faulty connection or a software issue. To troubleshoot, first check all the connections between the head unit and the speakers to make sure they are securely connected. If the connections are secure, then check the wiring connections to make sure they are not loose or frayed. If the wiring connections are good, then the problem could be with the head unit itself and you may need to contact a professional for further assistance. For the second issue, it could be due to a faulty connection, a wiring issue, or a software issue. To troubleshoot, first check the speaker wires to make sure they are connected properly and not loose or frayed. If the wires are secure, then you should check the setting on your amplifier or stereo to make sure the rear speakers are enabled. If the rear speakers are enabled, then the problem may be with the wiring or with the head unit itself and you may need to contact a professional for further assistance.
1/4/2023 12:56:23 AM • Pioneer Car... • Answered on Jan 04, 2023
Pioneer DEH-6400BT CD receiver. Lay out of pins on a 6400BT please?
Question edited for a lot more clarity. Please always include FULL 'make model (what it is)'. Question moved from Refrigerators category!! Aanswer in the link https://www.google.com/search?q=pioneer+deh-6400bt+wiring+diagram ..
12/31/2022 6:35:51 AM • Pioneer Car... • Answered on Dec 31, 2022
Pd-f507 display needs adjusting?
There certainly are no instructions in the user manual on increasing brightness of the display. I can't guess whether Pioneer's own support would address this concern for this discontinued model. Several appear available on Ebay for between $63 and $160. The service manual doesn't appear to address your concern: https://www.manualscenter.com/manuals/pioneer/pdf407-service-manual.html#.Y6yZgBXMJsc https://www.pioneerelectronics.com/PUSA/AboutPioneer/Contact+Us
12/28/2022 7:44:26 PM • Pioneer Car... • Answered on Dec 28, 2022
How can I download the English version for Pioneer Carrozzeria MRZ99 please?
Japanese only on this model. How do I change the language on my Pioneer carrozzeria? Question : I have a carrozzeria AVIC-****. Can I switch the language to English ? Answer : Carrozzeria AVIC-**** is car navigation & AV model designed and sold for Japanese market only. The language cannot be changed to English, French or any other languages, and the instruction manual is in Japanese only. ..
12/23/2022 10:50:21 PM • Pioneer Car... • Answered on Dec 23, 2022
2answers
Hello all! I need the manual for the frequency converter Pioneer vf-5000? Could You help me with this?
Hi, please call the manufacturer and ask them to email you the manual or check with a seller of the product on the amazon or ebay websites and ask for the manual. They should be able to create a product listing for you to acquire it. Thank you.
11/10/2022 4:01:13 AM • Pioneer Car... • Answered on Nov 10, 2022
Pioneer DEH-P8500MP CD Player Logo
14 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
just wondering pioneer deh p4000ub cd
  • Car Audio & Video
