20 Most Recent Audiovox VE727 7 in. Under Cabinet TV Questions & Answers
The LA7833 is a monolithic linear IC for vertical deflection
output for large color television sets,this ic will need to be replaced after finding the fault that caused it to burn in the first place.
Audiovox VE727 7... | Answered on Jun 01, 2014
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Audiovox VE727 7... | Answered on Dec 07, 2011
Contact Audiovox directly to request the schematic diagram you need.
Audiovox... | Answered on Jun 06, 2019
Jim,
First thing I would do is try a different DVD to see if the problem persists. Otherwise, this device is equipped with integrated speakers, meaning it is unlikely that you will be able to replace them. You may be in the market for a new Audiovox, unfortunately; but before you scrap it I suggest taking it to a local electronic repair store near you.
Hope this helps,
Best regards
Audiovox... | Answered on Mar 08, 2019
Fixya does not sell Audiovox battery packs.
Audiovox... | Answered on Dec 28, 2018
I I had a similar problem. What worked for me, was resetting the player. By pressing the picture button on the player itself three or four times I got to the reset option. Press play when it says press ok to reset. My remote automatically started working at that point. Hope this works for you
Audiovox... | Answered on Nov 06, 2018
are you using the right remote, one time i tried to change things and come to find out it was on the dvd not the tv
Audiovox... | Answered on Sep 07, 2018
Fixya is unable to suggest sources for battery pack rbl 533.
Audiovox... | Answered on Jul 31, 2018
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device
Audiovox... | Answered on Dec 14, 2017
Audiovox VE727 7 in. Under Cabinet TV Logo
5 questions posted
Top Audiovox Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Televison & Video
Most Popular Question
fix television burn la7833 when turn tv
  • Televison & Video
