20 Most Recent Mitsubishi WD62327 TV Questions & Answers
How many times the standby LED flashes at a time?
Mitsubishi... | Answered on Aug 04, 2012
where is the lamp housing located?
Mitsubishi... | Answered on Oct 23, 2011
it sounds like your color wheel is defective. This can be easy depending on your level of repairing. you will have to remove the light engine to check it. the color wheel is located in the light tunnel itself. if it is broken you will see the colored segments in pieces. the color wheel number is located on the ribbon. with some of these models you may have to order a new or used light tunnel with the color wheel. I am pretty sure this is the right one i have for sale the numbers dont have to match exactly but they use the same color wheel. here is my ebay item number 130486082582 just do a search on ebay. If the numbers in pic 3 are the same then you can use the whole part.
Mitsubishi... | Answered on Feb 22, 2011
12 Jul 2006 ... Prices from $2145 ' Pros and Cons, Videos, Amazon Reviews, and Support. Read the full unbiased report on the Mitsubishi WD-62327.
www.productwiki.com/mitsubishi-wd-62327/ - United States - Cached
Hope that helps.
Mitsubishi... | Answered on Feb 16, 2011
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input/or device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Is it 2X2 error blinks ?????
Good Luck!!
Thanks!!
Mitsubishi... | Answered on Aug 02, 2010
Well usually, a Lamp is good for many, many, thousands of hours, It is more than likely a Power Supply issues, a lot of the time it is, in my shop anyway.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Mitsubishi... | Answered on Apr 08, 2010
Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
Mitsubishi... | Answered on Feb 09, 2010
is there sound. first check the secondary filter capacitor and then check for dry join. don't forget to check the HOT transistor.
Mitsubishi... | Answered on Jan 21, 2010
check for dry join at the vertical section. and at the HV section.
replace the power pcb in the tv.
Mitsubishi... | Answered on Jul 15, 2009
About the second user with the remote problem, the problem is likely a bad IR sensor/board inside the TV, The IR circuit is the one that receives the remote signal.
About the original problem with the light blinking instead:
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Mitsubishi... | Answered on May 05, 2009
is this a new tv what ever the problem try to see what settings you are on like factory or custom
okay if on factory put on custom and try to adjust to your likings what i like to do is take the color settings all the way down try to make a black and white tv like the old days then start bringing
the color up see what happens okay good luck
Mitsubishi... | Answered on May 03, 2009
A friend of mine had the same problem. It is dust on the mirrors, but I recommend you have it professionally cleaned. They had theirs done and it fixed the problem
Mitsubishi... | Answered on Apr 19, 2009
Let me know brand and model number of your TV to look for its Instruction Manual for you.
Mitsubishi... | Answered on Dec 05, 2008
Well I bought my about three years ago and that warning was poping on for about a year. The lamp finally went out, I should have got a replacement sooner. But I ran it longer than it should have gone, I think I read the lamp should last about 2 years, I got an extra year out of it. Oh well time for a new one...
Mitsubishi... | Answered on Jun 23, 2008
Televison & Video Logo
26 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
tv power light comes but screen black
  • Televison & Video
