20 Most Recent Aqua Vu Scout SRT Fishfinders Questions & Answers
Check your camera cable & 'FISH' camera for kinks,punctures, or tears. Reconnect the cable into the monitor. Have a nice day.
Aqua Vu Scout... | Answered on Jan 11, 2016
Check the battery voltage. It should read around 12 volts. I have the same unit that did the same thing. The battery voltage was down to 6.5 volts. That was enough to power the LED but not enough to run the unit. Once I used a known good battery everything worked fine. Good luck!
Aqua Vu Scout... | Answered on Feb 08, 2011
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Boating | Answered on Aug 29, 2020
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Boating | Answered on Aug 26, 2020
First, make sure that you are trying a lifejacket that fits your weight and height. The best way to test it is to work in a pair. Hold your hands straight above your head and have someone else pull up the tops of the arm openings. If the jacket covers your face or chin, it is too large.
Boating | Answered on Aug 25, 2020
It should be on the makers tag sewed onto the jacket
otherwise contact the manufacturer on the net
I think that google might have a manual for your 1996 35 doral SC. You can always try searching on google and type in the google search engine.
Boating | Answered on Aug 04, 2020
Only three ways
Connect a transducer or head unit from a friend.
Buy a new one.
Return it to the factory for testing.
Does your mystery fish finder have a demo mode? That _should_ prove if the head unit is olay.
Boating | Answered on Aug 03, 2020
Not sure if this link will help
https://www.bitchute.com/playlist/zdU7Ihae6i4C/
A little history on the glastex later sold as sea star and sea spirit
http://www.fiberglassics.com/library/index.php?title=Sea_Sprite
Boating | Answered on Jul 06, 2020
CHECK WITH THE MANUFACTURER IS ALL i can suggest as a fix NOT SOMETHING A DIYER HAS THE CAPACITIES TO DO
Boating | Answered on Jun 25, 2020
Hey Bill, NADA does not list a 2605 for 2009..
is this an outboard or stern drive..
2009: 2301 WA STRIPER 24' STERN FG 1 220 4450 8'6" Gasoline 2301 WA STRIPER(**) 24' OUTBD FG 1 200 3850 8'6" Gasoline 2601 CC STRIPER(**) 26' OUTBD FG 2 150 4250 8'6" Gasoline 2601 WA STRIPER 26' STERN FG 1 270 5150 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 2 150 4550 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 1 225 4550 8'6" Gasoline 2009 Seaswirl Boats Prices Values
Boating | Answered on Apr 21, 2020
GOOGLE IT WITH THE MAKE STATED FIRST
This one?
https://www.walmart.com/ip/Electronics-Built-In-Bluetooth-Marine-Antenna-Cone-USB-DIN-Speakers-Stereo-LCD-Range-Two-Port-WCP365BT-Single-Long-inch-Dual-6-5/658806335
RT is normally reserved for transmitting, this is a receiver. Or is it linked to a two way transceiver and automatically cuts out music for telegraphy transmissions coming in?
I can't find the manual for it. The reviews at the lower part of the page suggest it is a bargain basement unit. I have a Jenson :>)
Boating | Answered on Apr 11, 2020
the #1 failures all all things with batteries are.....
1: battery bad.
2: battery bad.
repeat
not only that, but a bad battery makes the charger lie..
do you understand why, that is easy an old battery may still work some, and have 1/10 capacity left, but the charger does not know that, so lies to you. (only load testing proves any of that)
Boating | Answered on Mar 27, 2020
Aqua Vu Scout SRT Fishfinders Logo
13 questions posted
Top Aqua Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you an Aqua Boating Expert? Answer questions, earn points and help others
View Most Popular
Aqua Boating
  • Aqua Boating
Most Popular Question
screen camera lite up but no
  • Boating
