20 Most Recent
Samsung Xpress C410W Laser Printer Questions & Answers
Samsung c410W won't print
HI
it seems to me that you might gotten the wrong driver install in your system.
error page - Position: )x42b (1067) System: h6fwaim_mono/xl_image Line: 132 Version: QPDL 5.04 04-25-2005
do a check on your OS version. Operating system. right click mycomputer icon -> properties.
download the correct version of driver from Samsung website again. uninstall the currect version and unplug the usb cable to the printer.
restart your system, install the downloaded correct version and plug in the usb cable to the printer. do a custom install to serach for the printer. if it does search the printer. it will show you. USB001. after install you will be prompt to do a test page. test on it to see it works.
if it does not work after downloading and install the driver. You might have a mainboad firmware corruption.
to run a firmware update is not easy it might course other major issue. only install by an trained Samsung Engineer.
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
