20 Most Recent
NetTV PDP42V Television Questions & Answers
I have an lg pdp42v7 that suffers from pixel
there are 2 voltages that nned to be correct
if not they could be causing you problem ,and i hope that is the case. otherwise you willl need an epnsive panel replaced i would suggest you have a tech take a look
Redi remote control manual for an genessis g506 for sound system
Redi remote control manual for an genessis g506 for sound systemGENESIS G506 REMOTE CONTROL MANUAL1. Battery InstallationThe GENESIS G506 remote control requires two AAA batteries. To install the batteries:a. Remove the battery compartment cover by pressing the release tab on the back of the remote.b. Insert two AAA batteries into the battery compartment with the correct polarity.c. Replace the battery compartment cover.2. Setting Up the RemoteOnce the batteries are installed, you will need to set up the remote for use.a. Press and hold the MODE button for 3 seconds to enter setup mode. The red LED will flash twice.b. Press and release the DEVICE button to select the device you want to control. The LED will flash once for each press.c. When the desired device is selected, press and hold the MODE button for 3 seconds to save the selection. The red LED will flash twice.d. Repeat steps a-c for each device you wish to control.3. Using the RemoteOnce the remote is set up, you can use it to control your devices.a. Press the DEVICE button
TCL 43S425CA - stuck on set up loop. Do I need a board replacement of any kind?
If your TCL 43S425CA TV is stuck in a setup loop, it is likely an issue with the software or firmware of the TV. Here are a few things you can try before considering a board replacement:
- Power cycle the TV: Unplug the TV from the power source, wait for a minute, then plug it back in and turn it on.
- Update the software: Check if there is an available software update for your TV. If so, update the software following the instructions provided by the manufacturer.
- Factory reset: If the power cycling and software update do not resolve the issue, you can try a factory reset. This will erase all of your settings and return the TV to its original state. Check the manual for instructions on how to perform a factory reset.
- Contact the manufacturer: If the issue persists, it may be a hardware problem and you may need to contact the manufacturer for a repair or replacement.
Note: It's always best to check the manufacturer's website or manual for the latest troubleshooting information and support options. Before you decide to replace any board, make sure that you have a warranty for the TV or if it's an old one, then it may not be cost-effective to get it repaired.
Where is the 5 amp fuse providing 12 power to the display on thetford fridges
The 5-amp fuse that provides 12V power to the display on your Thetford N180 fridge is most likely located in the main fuse box. Some Thetford fridges have a separate fuse specifically for the display, but others use the main fuse for power to the display and other components.
I would recommend checking the main fuse box again to make sure that the appropriate fuse is in place and that it is not blown. If it is in place and not blown, you can check the wiring leading to the display to ensure that there are no loose connections or damage to the wires.
If the fuse and wiring are fine, the issue may be with the display itself and it may need to be replaced. If you are not confident in troubleshooting the issue, it is recommended to seek assistance from a qualified technician.
User manual with pictures of aim flat screen cz 1832
Unfortunately, it is not possible to provide a user manual with pictures for the Aim Flat Screen CZ 1832. However, you may be able to find the manual and other related information for the TV on the manufacturer's website. Additionally, you may be able to find the manual and other helpful information on sites like ManualsOnline.com.
