20 Most Recent Orion Xtreme XTR15 Car Speaker Questions & Answers
If the speakers measure zero ohms, then the coil is shot. A speaker will not work if it has zero ohms. Replace the speaker. ALL speakers should read 4ohm, 8ohm or above. Zero means the coil wire is shoted. That there is no continuity.
Orion Xtreme... | Answered on Apr 03, 2010
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Orion Xtreme... | Answered on Mar 05, 2009
well if your talking material i would go with heated plexy glass it has a better feed back
Orion Xtreme... | Answered on Feb 06, 2009
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Orion Car Audio... | Answered on Feb 06, 2019
Request the schematic diagram directly from Orion.
Orion Car Audio... | Answered on Oct 05, 2018
You do not have enough listed for specifics but you do need to match your sub with the amp from an ohm standpoint and a wattage standpoint. I am sure your amp can handle down to 4 ohms but may handle 2 ohms. Find that out and then check on the output wattage of the amp. A lot of people have separate amps for the sub itself and run the system off of another amp. Either way is acceptable.
Orion Car Audio... | Answered on Mar 23, 2016
box size? look it up on google in the specs or manual for your sub. it should say whats it is. bigger is better unless you have a sealed box or rubber surround
Orion Car Audio... | Answered on Apr 28, 2015
http://www.devicemanuals.com/manufacturer/ORION%20.html
this link should help it helped me
Orion Car Audio... | Answered on Mar 03, 2015
Orion Xtreme XTR15 Car Speaker Logo
3 questions posted
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Roy Funkhouser
Roy Funkhouser
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Orion Car Audio & Video
Most Popular Question
older 15
  • Car Audio & Video
