20 Most Recent
Polaroid 16MP Slim Digital Camera 2.4-Inch Screen IS536-BLK-MCF Questions & Answers
Camera not working
Unfortunately, if the batteries have corroded then the chances are extremely high that the contacts (and possibly more of the camera's internal electronics) have also been affected by corrosion. It may be possible to clean the contacts yourself, but if there is corrosion internally then the camera is probably not economically repairable.
Polaroid iD1660 not accepting memory card
you dont say what size or type of card you have there? did you previously use the card elsewhere? format the card on a PC using SDFORMATTER (google it) hope that sorts.
Delete amazon account
A factory reset will restore your Kindle to factory conditions and removes any content you've downloaded to your device, be sure to back up your personal content to your computer first. You will be able to download all your Amazon purchases from Archived Items after registering a new device or application.
To factory reset your Kindle:
1. From the Home screen, press Menu.
2. Select Settings.
3. Press Menu again and select Reset to Factory Defaults.
Your Kindle will then begin to reset. This may take a few minutes to complete.
Sotwere para polaroid i531
Hi there:You don't need special software to transfer photos to your computer if you have a USB port on your computer and a USB cable that will attach to your camera on one end, and the USB port on the other.Plug the camera into the USB port by means of the cable, and turn on your camera. That's all there is to it. In just a moment or so, a message will pop up to tell you that your USB drive is ready to use. You may even get a pop up asking what you want to do?Select "Open Files", or if the pop up option does NOT pop up, open your "My Computer", and you will see an additional hard drive. That hard drive is actually your camera, and you can go in, copy all the photo files onto your hard drive, delete them from your camera, or anything else you would do between two folders on your own hard drive.However, I suggets visit THIS LINK or this OTHER LINKHope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
