20 Most Recent Dyson DC58 Bagless Cordless Hand Vac Questions & Answers
My Dyson DC58 goes on and off in max mode
Hello, this is Ava with Think Crucial. There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this. You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=dyson+dc58 I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
12/7/2016 5:39:05 AM • Dyson DC58... • Answered on Dec 07, 2016
tip
Dyson DC58 or DC61 - vacuum makes a pulsing sound (removing a blockage)
Dyson DC58 and DC61 handheld vacuum cleaners are engineered to make a pulsing sound to let you know if they're blocked. This could happen if an item too large for the machine is accidentally vacuumed up. Our video support guide will help you identify and remove any obstructions.
How to clean a Dyson DC58 dust container thoroughly?
Hi there, it's Jack at Dyson. Removing the clear bin is simple to do. Press the red bin base release catch once, as if you were emptying the vacuum. Then with the bin base still open, press the same red catch a second time to disengage and remove the clear bin. Once you've done this, you can use a soft brush or dry cloth to remove any fluff or debris from the mesh shroud. 1dd3bf5d-e3f0-49cb-affa-f8d1d3bd588b.jpg You can replace the clear bin afterward by aligning the tab on the cyclone back with the notch on the inside of the clear bin, then pivoting the bin back into place. I hope this helps, but if you'd like any further advice you're welcome to get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
9/17/2014 8:35:00 AM • Dyson DC58... • Answered on Sep 17, 2014
Dyson Animal V6 flashing blue and red?
two faults, mainly battery. A flashing blue light indicates that there is no power, please charge the battery. A flashing amber light indicates that there is no power or a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, please call the Dyson Helpline.
Support and How to Guides for your Dyson V6™ Vacuum
3/19/2024 2:47:52 AM • Dyson Vacuums • Answered on Mar 19, 2024
2answers
Dyson DC41
12/31/2023 6:14:55 PM • Dyson Vacuums • Answered on Dec 31, 2023
Is the base of a Dyson AM05 the same as a Dyson AM09?
Question edited for clarity. No it is taller https://www.google.com/search?q=dyson+am05+vs+dyson+am09 ..
12/29/2023 5:30:50 AM • Dyson Vacuums • Answered on Dec 29, 2023
The bottom of the clear canister opens before I am ready...have to re-vacuum. Lock not working correctly. Seems secure when attaching & vacuuming...just falls open before I can remove it.
Check for dirt in tracks of closure mechanism, clean as nessary. Also, check worn mis-aligned, adjusted clasp.
8/17/2023 5:30:43 AM • Dyson Vacuums • Answered on Aug 17, 2023
How to fix the Dyson dc21 motorhead
6/22/2023 11:22:43 AM • Dyson Vacuums • Answered on Jun 22, 2023
Dyson airwrap hair styler turns off at some heat settings and red light is blinking
If your Dyson Airwrap hair styler is turning off at certain heat settings and the red light is blinking, it could indicate a potential issue with the device. Here are a few troubleshooting steps you can try: 1. Check the power supply: Ensure that the Airwrap is properly plugged into a functioning power outlet and that the power cable is securely connected to the device. 2. Reset the device: Unplug the Airwrap from the power source and wait for about 30 seconds. Then, plug it back in and try turning it on again. This reset may resolve any temporary issues. 3. Clean the filter: The Airwrap has a filter located near the base of the handle. Check if the filter is clogged with dust or debris. If so, gently clean it with a soft brush or by rinsing it under running water. Allow it to dry completely before reinserting it into the device. 4. Check for overheating: The red blinking light on the Airwrap can also indicate that the device has overheated. If this is the case, it may have an automatic shut-off feature to protect against damage. Allow the Airwrap to cool down for a while before using it again. Make sure the vents on the device are clear and not blocked by hair or other obstructions. 5. Contact Dyson support: If the issue persists after trying the above steps, it's recommended to contact Dyson customer support for further assistance. They can provide specific troubleshooting advice or arrange for repairs if necessary. Remember to refer to the user manual or Dyson's official support channels for the most accurate and up-to-date information regarding your specific model of the Dyson Airwrap hair styler.
6/21/2023 9:21:46 AM • Dyson Vacuums • Answered on Jun 21, 2023
My Dyson n AM09 keeps flashing red light and shows 42
The Dyson support site has choices of visible issues about led staying on, letters f, c, h showing, or many other options
https://www.dyson.com/support/journey/troubleshooting/61874-01/visible-issue-243255
6/12/2023 3:30:24 AM • Dyson Vacuums • Answered on Jun 12, 2023
I purchased a genuine Dyson bin replacement and when I try to shut the bin lid after I put the new one in it won't close.
Where did you order the 'Genuine Part' from. It sounds like a Genuine copy made in China like the brush that was sent to me. Genuine parts only come from Dyson direct. Mine came from Amazon. https://www.google.com/search?q=genuine+dyson+bin+replacement ..
3/14/2023 4:57:46 AM • Dyson Vacuums • Answered on Mar 14, 2023
Broken latch on Dyson dc77/up14
1/23/2023 11:43:52 PM • Dyson Vacuums • Answered on Jan 23, 2023
On my dyson 02-89666B. The power head keeps shutting off when I go to vacuum. When its not flat on the floor it works
If the vacuum cleaner's airways become blocked, the device will automatically shut off to prevent damage. Check for blockage at the power head. It probably runs when not flat because it can suck air past the blockage. If the vacuum's filter is full of debris, the vacuum may lose suction, causing the device to turn off automatically...which I doubt in your case. Be cautious removing the blockage for sharp objects. Best to you
1/23/2023 8:19:56 PM • Dyson Vacuums • Answered on Jan 23, 2023
2answers
How do I stop my Dyson vacuum from whistling?
fix the vacuum leak probably an incorrectly fitted canister , or seal ring missing
1/19/2023 4:37:31 AM • Dyson Vacuums • Answered on Jan 19, 2023
What size Torx screwdriver do I need to fix a Dyson V8
You ONLY need a T15 for these models DC01, DC02, DC03, DC04, DC05, DC07, DC08, DC14, DC19 and DC25. If you are going to be working on models such as the the DC24 and other later Ball machines like the DC15 and DC18, and newer machines like the DC39, DC40 and DC41, not to mention new Cinetic machines, you will also need a T10 with an anti-tamper end and also a T8 for some jobs. If you are planning to repair later models, get a T8, T10 T and the T15 T (The extra "T" denotes anti-tamper).
1/14/2023 8:03:19 AM • Dyson Vacuums • Answered on Jan 14, 2023
Dyson DC58 Bagless Cordless Hand Vac Logo
5 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
dyson dc58 goes off in max mode
  • Vacuums
