20 Most Recent Xerox WorkCentre Pro 423 Copier Questions & Answers
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Xerox WorkCentre... | Answered on Jun 19, 2019
check your scanner for obstruction
Xerox WorkCentre... | Answered on Apr 20, 2013
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Xerox WorkCentre... | Answered on Mar 21, 2012
i have a xerox 423 with u2-3 error code whats that
Xerox WorkCentre... | Answered on Sep 01, 2011
pro 423 doesn't support vista or win 7
Xerox WorkCentre... | Answered on Jul 25, 2011
no way . u have to get new one and fix it
Xerox WorkCentre... | Answered on Jul 01, 2011
You can always find your solution to a Xerox problem at the Xerox Knowledgebase. Here is the direct link to this solution with pictures! http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=467,E=0000000002703228701,K=8434,Sxi=4,Case=obj(862)
Solution : Replace the Drum / Toner (Dry Ink) Cartridge
CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. If not, launder your clothes with detergent and cold water. If the fabric label says to dry clean, inform a commercial dry cleaner that the spot is Toner so that they will not use a solvent that will set the stain.
NOTE: Make sure the Cartridge part number corresponds to the machine model. If an incorrect Cartridge is installed the message 'Check Drum / Toner (Dry Ink) Cartridge Message' will continue to appear on the machine display.
  1. While lifting the upper, right-hand cover release lever of the machine, pull the upper right hand cover towards the right until it stops.
  2. Open the Front Cover on the machine.
  3. Grasp the Cartridge by the handle on the front, and slide it toward you until the top handle is completely clear of the machine.
  4. Lift up on the top handle and slide the cartridge out of the machine.
  5. CAUTION: Do not shake the cartridge and this could cause the Toner to spill.
  6. Before you remove the new cartridge from the bag, shake it vigorously from side to side several times to loosen the contents.
  7. Holding the new cartridge by the top handle, begin sliding it into the machine as indicated in the picture above. Do not push on the handle on the front of the cartridge as the cartridge will jam.
  8. Hold the cartridge in place and pull the Toner seal tape until the cartridge is completely in place.
  9. Close the Front Cover.
  10. Close the upper right-hand cover.
  11. If necessary, press [C] on the Control Panel to clear any messages. The system will initiate a Copy Quality adjustment cycle after you press the [Start] button.
Xerox WorkCentre... | Answered on May 29, 2011
Dear download the driver and re install your problem wil;l be get resolved make sure you have the pst script function enabled, if not please install pcl 6 driver.
Xerox WorkCentre... | Answered on May 15, 2011
Heater lamp abnormal temperature detection .
Xerox WorkCentre... | Answered on Mar 25, 2011
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Xerox WorkCentre... | Answered on Mar 19, 2011
Xerox WorkCentre Pro 423 Copier Logo
56 questions posted
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
reset drum
  • Office Equipment & Supplies
