20 Most Recent Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Questions & Answers
If you type "showmax on hisense smart TV" in google it will give you several sites that tell you how to set it up. One claims to only take 2 minutes. Give this a try.
Hisense 50 Class... | Answered on Nov 19, 2018
Recheck your router to see if the mac address of the TV is listed on the wifi setup page. On the TV, make sure the router password is entered correctly
Hisense 50 Class... | Answered on Jul 23, 2016
There could be an issue in the power supply. I am assuming here that there is an external PS or power brick and some call it that plugs into the tv. Crack that open and take a look at the caps which look like little tubes or little boxes if any of them are blown open, bloated, or misshapen then that it more than likely your problem. Common misconception is that power strips safe guard you from power surges, but unless you paid big bucks like over 150$ then you have no surge protection other than your homes breaker box. Power supplies are easily replaced as they are the most common failure in televisions. If you don't notice anything that looks off, try buying a power supply from somewhere reputable like amazon.com where you can buy a power supply and return it if there is no issue. If you do find something let me know and I can help you find what you need.
Hisense 50 Class... | Answered on May 04, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Hisense 50 Class... | Answered on Apr 07, 2016
Hope the TV have problem with the either power board or the lcd panel. Try to check the power supply is its produce correct voltages mentioned on its connectors if you need help then check the video for that. if the power supply finds ok then you have problem with the lcd panel. In lcd panel there is a some ics which used as the driver of the pixels. the tcon sends data to these ics. and if any onf the ics draws more current from t con board then it can dame the t con. They are not replaceable one ,its integrated to the panel. if its faulty then you have to go for a new panel for that tv. And it would be a expensive repair.
Testing LCD TV Power Supply BoardsSTEP BY STEP
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
Hisense 50 Class... | Answered on Nov 11, 2015
ever try to adjust the contrast or colors , in the main menu
Hisense 50 Class... | Answered on Oct 24, 2015
Recommend using the installation and setup procedures straight from the manual. Unfortunately, I cannot access the manual, but I recently set up a new Smart TV and found that the manual is essential to making it easy and painless. The added benefit was that I learned how to properly use my TV easily.
Good luck,
Hisense 50 Class... | Answered on Mar 02, 2015
There might be a setting on your cable box for audio output. Use the cable remote and look in the audio section of the settings menu and select HDMI output. Mine is under Audio Digital Output in the Audio/Video menu.
Hisense 50 Class... | Answered on Feb 21, 2015
Run network wizard.
Hisense 50 Class... | Answered on Feb 08, 2015
Check your settings and also check for a firmware update for your router.
Hisense 50 Class... | Answered on Dec 03, 2014
Currently there is not a firmware update for that model.
Here is the user manual in case you need it.
http://hisense-usa.com/support/manuals/50K610GW_us_M_en_man.pdf
If the panel lock is set to ON, the panel buttons won't work. If the remote control or the infrared sensor inside the TV is faulty; the remote control won't respond. Contact any service technician. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Hisense 50 Class... | Answered on Nov 26, 2014
Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Logo
24 questions posted
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
new 50 hisense tv unable use hdmi
  • Televison & Video
