20 Most Recent Xandros Desktop OS v.3.0 Deluxe Edition - License & Media - License and Media - 1 User Retail - Multi-platform - English Questions & Answers
Befoe reset ur pc than after use your softwere cd
Xandros... | Answered on Mar 03, 2012
You can try to use RecoveryFix for BKF recovery software to restore your deleted file. For more details you can downlaod this software: http://www.bkfrestore.org/download-free.html
http://msbkfrecovery.blogspot.com/2012/08/get-access-to-your-corrupt-or-damaged.html
Computers &... | Answered 3 hours ago
This Error with migration of data occurs when the connectivity is not proper with the Tally ERP ODBC. It includes the IP:Port.
The Default port for Tally ERP is 9090.
To change the port go to the installed tally ERP 9 folder. Click on Tally file type Configuration Settings, open it with a text Editor i.e. Notepad. Somewhere at the bottom will be ServerPort. Change the ServerPort to 9090. The migration will work. I have tested. Works fine with me.
Computers &... | Answered 4 hours ago
go into settings and then look for firmware and if it has upgrade firmware then you might be able too!!!!
Computers &... | Answered 8 hours ago
do you have rooted you android? if so you have apps for that and they work (i tested myself on mmotorola atrix) if you dont have root i cant help
INSTRUCTIONS FOR INSTALLING SSL ON DIRECTADMIN BKHOST VN
I. Create CSR on DirectAdmin
1. Login to DirectAdmin and click on the "SSL Certificates" option as shown in the picture
B2: Check the boxes 1 and 2 as shown below. Section 3 fills in your email. Key Size (bits), Certificate Type select as shown below. Then drag the mouse down and click "save".
Note: SSL is currently enabled for this domain.
B3: Activate SSL on Hosting DirectAdmin
Part Your Account => Domain Setup => click on the domain you need to install SSL. Most importantly, you must check the 2 boxes as shown below.
Secure SSL and Use a symbolic link from private_html to public_html - allows for same data in http and https
B4: After installing SSL successfully, you can go to the online check ssl page to check again as follows:
https://blog.bkhost.vn
The next step Really Simple SSL
We were able to use the https protocol for the website after completing this step. If you are already using wordpress website, you need to install Really Simple SSL to complete installing SSL certificate for your website.
It is done!
Computers &... | Answered 9 hours ago
There are several brands that make that model. What one do you have?
Computers &... | Answered 14 hours ago
it may also be called on-line currency, cyber currency, or the actual name of the currency for that particular game
Computers &... | Answered 15 hours ago
Install codec to your PC. You can download the codec here.
Computers &... | Answered 17 hours ago
Not being someone especially savvy in coding, I can only help so much, but I would say that a fake payment gateway would probably be more work than you're actually looking to do. If you just want a cart or payment button of some kind, embedding an image as a placeholder might be able to give you the look you want without involving the time-consuming process of creating the code yourself. Alternately, I would look into using some kind of free or very cheap program or service to use on your website. It depends on what kind of functionality you do and don't want, but I'd look into some of the payment gateway integrations in Magento, like PayUMoney.com, that doesn't demand an account be made at the checkout. That might be a good solution that gives you some of the functionality that you need for your project, but without the commitment that other services might demand.
Computers &... | Answered 18 hours ago
NOT REALLY
Computers &... | Answered 19 hours ago
All your files are still stored on the hard drive.They're just invisible or inaccessible.You can recover them with data recovery software.
http://www.asoftech.com/adr/
You can try to use third party Access file recovery program to recover your lost and corrupted data from .mdb files. For more details about this software:-
Access File Recovery Software
Computers &... | Answered 20 hours ago
Hi Barry,
Can you please share what is the exact error message you are getting
Keep using FixYa.
Subhankar Ghosh
Computers &... | Answered 21 hours ago
How to Remove VBA Password - VBA Password Remover Tool to quickly or reliably recover VBA password. This software recover VBA password from your sheet/workbook project password and open MS office files. Source link:- http://www.advance.vbapasswordrecovery.net/
Computers &... | Answered Yesterday
To transfer pictures from your computer to your Android 2.2 device, connect the Android device to the computer by the USB cable. This should pop up a "USB connected" message. Click the Turn on USB storage on the Android device. If this doesn't show up, you might have to pull down the top notification bar on the android device and select "USB connected" first.
Once you choose to turn on USB storage, you will get a message asking you to confirm, as it can cause running applications to crash if they need to use the SD card. Select OK once you have confirmed you have no running applications that need the SD card.
After a few seconds your computer should have recognized it and pop up a message asking you how you want to use the device. Select view folder. If it doesn't pop up, you can always go to My Computer and open the drive named after your Android device.
To copy the files simply drag them from their current folder to the folder you want them to be in on your Android device. Please pay attention to the symbol on the file icon as you drag, as depending on system settings you might be either moving or copying the files. Shift and Ctrl will toggle this setting to the other one before you release the mouse while holding them.
Please leave feedback if this was helpful. Thanks.
Xandros Desktop OS v.3.0 Deluxe Edition - License & Media - License and Media - 1 User Retail - Multi-platform - English Logo
0 questions posted
Top Xandros Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Xandros Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Xandros Computers & Internet
Most Popular Question
installing operating system
  • Computers & Internet
