20 Most Recent Crosley CR78 CD Shelf System Questions & Answers
I have had a couple of drives with that symptom. Tried cleaning the guide rails and applying a drop of silicone lube to the rails. No change. Concluded the little motor was becoming too weak to close the tray, so back to the nudge and hope routine
Crosley CR78 CD... | Answered on Apr 20, 2013
This type of problem occurrs due to spring which is installed in
the system. Bring a spring from the market for that product. After
that open the system and remove the old spring and install new one.
After that check the power cable which is connected with the outer
switch. If it has no power then changes the power cable also.
Be careful, If you have no proper tools to open the system then buy tools from the market. Otherwise your system may be damaged.
Crosley CR78 CD... | Answered on Aug 15, 2011
Lift platter and refit belt. [email protected]
Crosley CR78 CD... | Answered on Sep 15, 2010
The home page for Cosley =
"http://www.crosleyradio.com/prods/cr78.html"
Contact and support links are near the bottom of the page (RHS)
Contact them and ask them if they have a user manual in PDF
format for download.
Martin
Please rate my answers.
Crosley CR78 CD... | Answered on Jan 27, 2009
Hello Tom, you would have to measure if the engine gets power, also control the key that drives the engine when it starts
Check if you can move the motor shaft with your hand, to confirm that it is not locked
Good luck with the checks
Greetings Franco Dosil
Hola Tom, tendrias que medir si le llega alimentacion al motor, tambien controlar la llave que acciona al motor cuando arranca
Fijate si puedes mover el eje del motor con la mano, para corroborar que no esta trabado
Suerte con los chequeos
Saludos Franco Dosil
Crosley Audio... | Answered on Apr 19, 2019
Just visit a local radio spares shop. Crosley units are made in China and are low end units.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&biw=1920&bih=937&tbm=isch&sa=1&ei=q_STXL_JKI3wtAXU0I_YDw&q=volume+knob+for+a+radio
Or rebuild the old one by using epoxy putty..
https://www.jbweld.com/collections/epoxy-putty-sticks
Video
https://www.youtube.com/watch?v=5n0H05E9FQs
Crosley Audio... | Answered on Mar 21, 2019
There could be a CD jammed in the magazine. Some careful disassembly will be required to find what's wrong.
Crosley Audio... | Answered on Mar 06, 2019
There is no locking mechanism...you may have to pry it, but you are on your own! This is totally up to you as there could be any number of reasons why it is stuck...No responsibility on my end...
Crosley Audio... | Answered on Dec 04, 2018
Plug in your USB or SD card, select the correct input and you are good to go...
Crosley CR78 CD Shelf System Logo
8 questions posted
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
Gene Pitts
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Audio Players & Recorders
Most Popular Question
turn table
  • Audio Players & Recorders
