20 Most Recent
Brisk Air Dometic A/C Roof Top Air Conditioner Upper Unit 15,000 BTU 459516.XX1C0 Questions & Answers
1988 mallard sprinter travel trailer electric heat, how do I use it
To use the electric heat on your 1988 Mallard Sprinter travel trailer, you will need to follow the instructions for your specific Duo Therm Brisk Air unit. Here are the general steps you can follow to use the electric heat:
- Set the thermostat: Set the thermostat to the desired temperature. The thermostat controls the electric heat and determines when it will turn on and off.
- Turn on the electric heat: The electric heat on your travel trailer is usually controlled by a switch or a button on the thermostat or on the unit itself. Turn on the electric heat by flipping the switch or pressing the button.
- Adjust the temperature: Use the thermostat to adjust the temperature as needed. The electric heat will turn on and off as needed to maintain the desired temperature.
- Turn off the electric heat: When you are finished using the electric heat, turn it off by flipping the switch or pressing the button.
If you are having difficulty using the electric heat or are unsure about how to operate your specific Duo Therm Brisk Air unit, you may want to refer to the owner's manual or contact the manufacturer for assistance. They will be able to provide you with specific instructions for your unit and help you troubleshoot any issues you may be experiencing.
12/26/2022 12:08:34 AM •
Brisk Air...
Answered
on Dec 26, 2022
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
