20 Most Recent Hotpoint WML540P 60cm Washer Front Loading, 53L Questions & Answers
Try this. Unplug unit. While unplugged, hold in power button for about 10 seconds. Release plug back in. See if that has reset the control module. Works on some other makes. Can't hurt to try.
Hotpoint WML540P... • Answered on Mar 10, 2015
possible transformer shorted thats whats popping breaker
Hotpoint Washing... • Answered on Feb 28, 2021
Hi,There are basically just few reasons :1. Maybe the water pressure is too low2. Hoses are blocked - check that there are no kinks in the cold water fill hose and the waste water hose too3. Clogged inlet valve - the water inlet valve supplies hot and cold water.You can read more about most common washing machine faults here - https://www.justfixed.co.uk/washing-machine-problems/
You need a pulling tool and a press to put it back on. I would percivere with a blade and patience.
Hotpoint Washing... • Answered on Jan 31, 2021
remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
Hotpoint Washing... • Answered on Jun 25, 2020
Hello. If the problem happens every time you wash and is not an intermittent phenomenon, my first guess is your main control board has gotten corrupted somehow(there is a small computer program stored on the board which tells the machine how to operate dependent on which wash options you choose). I had to check extensively for the parts diagram to your unit--there is only one board that controls EVERYTHING...you will need to get the actual model number from the barcode sticker when trying to get this board. It will be located near or on the door. I hope I helped you!
Hotpoint Washing... • Answered on Mar 08, 2020
https://www.google.com/search?sxsrf=ACYBGNT6nLbuauU5ZByczrMC6cLaGIk6AQ%3A1581870161107&source=hp&ei=UWxJXtzCBND4aILKh_gH&q=General+Electric+Hotpoint+HTWP1400FWW+White+27.+The+washer+only+fills+to+half+on+the+rinse+cycle.+Ideas%3F&oq=General+Electric+Hotpoint+HTWP1400FWW+White+27.+The+washer+only+fills+to+half+on+the+rinse+cycle.+Ideas%3F&gs_l=psy-ab.3...223788.223788..226888...2.0..0.0.0.......1....2j1..gws-wiz.TGW-acS8eao&ved=0ahUKEwicr6DIvdbnAhVQPBoKHQLlAX8Q4dUDCAU&uact=5#kpvalbx=_n3NJXvmnM8GelwTnwpGQBQ28
Hotpoint Washing... • Answered on Feb 16, 2020
Hotpoint WML540P 60cm Washer Front Loading, 53L Logo
4 questions posted
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint aquarius wml540 drum turn after
  • Washing Machines
