20 Most Recent Bosch 30" 500 Series Over-The-Range Stainless Steel Microwave - HMV5052U Questions & Answers
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
11/28/2015 3:10:54 PM • Bosch 30" 500... • Answered on Nov 28, 2015
2answers
How do I turn off the demo mode on Bosch microwave model #hmc80252uc/05
I pressed Start/Enter and Clear/Off simultaneously for 3-5 seconds and it exited DEMO mode for me.
1/20/2024 10:05:27 PM • Bosch Microwave... • Answered on Jan 20, 2024
2answers
I have a bosch combination oven which is sparking when the microwave is running, around the bottom element location. Do you think I will need a new element and if so is this going to be expensive
to decide on that take it in to a repair shop to determine the cause of the sparking it could be a major problem or missing insulation so a proper diagnosis and quote will make it easier to decide
10/27/2023 4:27:53 PM • Bosch Microwave... • Answered on Oct 27, 2023
Bosch dishwasher soap dispenser wont open or drain.
If your Bosch dishwasher's soap dispenser is not opening or draining properly, here are a few troubleshooting steps you can take:
  1. Clean the Dispenser Area: Start by inspecting the soap dispenser area for any debris, soap residue, or obstructions. Clean the dispenser thoroughly using a damp cloth and remove any buildup that may be preventing it from opening or closing properly.
  2. Check for Mechanical Issues: Examine the dispenser latch and mechanism for any signs of damage or wear. Ensure that the latch is engaging properly and that there are no loose or broken parts. If any components are damaged, they may need to be replaced.
  3. Test the Dispenser Solenoid: The soap dispenser may be controlled by a solenoid that releases it at the appropriate time during the wash cycle. Check if the solenoid is functioning correctly by performing a continuity test using a multimeter. If the solenoid is defective, it may need to be replaced.
  4. Verify Proper Detergent Usage: Ensure that you are using the correct type and amount of dishwasher detergent recommended for your Bosch dishwasher. Using the wrong detergent or excessive amounts can cause issues with dispenser operation. Consult your dishwasher's user manual for specific detergent recommendations.
  5. Check the Drainage System: A clogged drainage system can prevent the soap dispenser from draining properly. Inspect the drain hose, drain pump, and any filters for blockages. Clear any debris or obstructions you find, and ensure that the drain hose is not kinked or bent.
  6. Reset the Dishwasher: Try resetting your Bosch dishwasher by turning it off at the power source or unplugging it for a few minutes. This can sometimes resolve temporary issues and restore proper operation.
If the above steps do not resolve the issue, it may be necessary to consult the Bosch dishwasher's user manual for model-specific troubleshooting steps or contact Bosch customer support for further assistance. They can provide you with specific guidance tailored to your dishwasher model and help you diagnose and resolve the problem.
7/15/2023 2:02:52 PM • Bosch Microwave... • Answered on Jul 15, 2023
2answers
I have a bosch microwave that will shut off after
Main power supply failure?
11/7/2022 12:23:50 PM • Bosch Microwave... • Answered on Nov 07, 2022
The panel on my one year old Bosch microwave is out. I can barely read numbers. What do I do?
Hey Myrna, can you please come again with your model number?
9/20/2022 8:47:32 PM • Bosch Microwave... • Answered on Sep 20, 2022
Bosch Microwave HBC 86Q650
This is concerning! https://www.houzz.com/discussions/3810147/how-to-change-light-bulb-in-bosch-built-in-microwave This video is for their ovens, but may help. In my experience of commercial microwaves, there is a door on the outside behind where the bulb is.
How to Change your Bosch Oven Bulbs - YouTube
https://www.youtube.com > watch 1:27 Watch our simple step by step instructions to replace the bulbs in your Bosch oven. YouTube · Bosch Home Appliances USA · Aug 31, 2018 https://www.google.com/search?q=Bosch+Combi+Microwave+HBC+86Q650+replace+bulb ..
1/26/2022 6:39:32 PM • Bosch Microwave... • Answered on Jan 26, 2022
Need a glass door for HME9750AU
There apear to be no listings for any spares except light bulb for your model. Not even a good second hand machine you could rob the door from, totally obsolete and time for a new one.
1/13/2022 9:25:40 AM • Bosch Microwave... • Answered on Jan 13, 2022
Model HMT84M651B/36. Why can't I set time?
On some microwave ovens (GE for one), you press a 'set time' button and rotate the knob to display the current hour then press the 'set time' button again and rotate the knob to set minutes.
7/24/2021 5:23:24 PM • Bosch Microwave... • Answered on Jul 24, 2021
Turning off demo mode on my bosch double ovens microwave 2020
try previous solution on fixya https://www.fixya.com/support/t29796790-turn_off_demo_mode_bosch_microwave_modeltry thisHold down the Start/Reset button for 3 seconds. The display will show: 0:01 2. Press the button and the Delay Start button at the same time.see mode 0 in settingshttps://www.manualslib.com/manual/767875/Bosch-Hmb5020.html?page=15
6/20/2021 8:07:49 AM • Bosch Microwave... • Answered on Jun 20, 2021
Model 5050/1. Why doesn't it latch?
The latch mechanism could be damaged or defective.
3/13/2021 3:04:36 AM • Bosch Microwave... • Answered on Mar 13, 2021
Bosch microwave oven dim display panel options to troubleshoot, model # HMC80151UC
There is a capacitor on the back board to the display. It needs replacing. They get dimmer and dimmer over the years
2/28/2021 6:22:32 PM • Bosch Microwave... • Answered on Feb 28, 2021
Panel light on Bosch microwave out but works fine. I'm just flying blind
I have had sometmes where bad solder connections on the display crystal stopped the display from working. May be worth a look at the connection on the main board where the display crystal is soldered to the board. If not, new main circuit board $$$$. Sharp uses a conductive rubber pad below the crystal to conduct power to the display. It is possible Bosch did something like that too. If so remove the main board, see how the crystal is connected to the board. Clean the rubber conductive pad or look for bad solder connections.
2/28/2021 5:32:29 PM • Bosch Microwave... • Answered on Feb 28, 2021
Bosch microwave diplay is dim
not possible
2/28/2021 5:31:23 PM • Bosch Microwave... • Answered on Feb 28, 2021
User manual for a Bosch Quantun Speed microwave HLK4555/01 please
Free multiple language manual online from Bosch. https://media3.bosch-home.com/Documents/9000455252_A.pdf
11/28/2019 12:05:17 AM • Bosch Microwave... • Answered on Nov 28, 2019
How to use Bosch Innowave as a microwave
Possible manual for a Bosch model Hmt84m651b since you don't specify exactly which model you need: https://www.manualslib.com/manual/274349/Bosch-Hmt84m651b.html?page=13#manual Bosch HMT84M651B Instruction Manual Page 13
11/4/2018 5:44:11 PM • Bosch Microwave... • Answered on Nov 04, 2018
Bosch 30" 500 Series Over-The-Range Stainless Steel Microwave - HMV5052U Logo
1 questions posted
Top Bosch Microwave Ovens Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Microwave Ovens
Most Popular Question
over range microwave doesnt fit in space
  • Microwave Ovens
