Sometimes these phone get stupid. Pull the battery out, wait about 30 minutes. Then put the battery back in, and turn it on. Go to your settings using a different method than you normally do, (they have a couple) and try rather than turning off your plane mode turn ON your mobile mode. Good luck.
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
The best way to unlock your phone is to buy unlock codes from a trusted vendor. Search internet for mobile phone unlocking websites. You will come across a thousand websites who can do this. Choose which ever you like. Do look for price comparisons and the unlocking instructions. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums. I used them to unlock my cell phone, contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Take out battery plug it into charger turn it on keep it on for 30 sec Unplug it,put battery back in an turn it on should work GOOD LUCK THIS PHONE SUX BUT THIS WORKED FOR ME
The wireless access point isn't passing DNS to your laptop. Go in an
manually assign 8.8.8.8 as the DNS setting.
Type ncpa.cpl into the Start menu search box or hit the Windows key + R
at the same time and type it in that box. Right click on the wireless
connection and select Properties. Go down to TCP/IP and select it. Click
Properties. Enter 8.8.8.8 in the Preferred DNS server box and click OK.
Click OK on the Wireless Connection Properties box.
Edit- Reboot your laptop with those new settings. I'll check back in
about 45 when I get home to see if you are still having problems.
2nd Edit - Type ncpa.cpl into the Start menu search box again to bring
up the Network connections screen. Right click on the Wireless
connection and select Diagnose. Let me know if that takes care of it.
What i would suggest you to do, is do a firmware upgrade, and then find a Jailbreak. Firmware upgrade will unlock your phone, but will clear it out of any passwords, and you will be able to use your sim once again. The only problem is that all the Data will be erased. Then, you will only have to find a jailbreak, and unlock it.
There are two types of lock.
A consumer set passcode lock. That is easy, you just do a hard reset, which deletes all the data and reloads the software as a clean install.
Or it is locked with a PUK Lock aka a SIM Lock.
https://www.fixya.com/support/r26056685-phone_asking_puk_code
You can take emergency action to avoid the data losing or reduce the data lost to the least as follows: 1) Get out your phone from the water ASAP, and remove and battery and take out the SIM card to reduce the loss or damage on the device; 2) Don't move or shake the phone frequently, so that the water will not run around your mobile phone inside; 3) Wrap the device with cloth or handkerchief for a few minutes, and then turn off your phone, and place it into a jar or a bag filled with rice for a couple of days. But if you find something important are lost,like contacts, don't worry, you can ask for help from MobiKin Doctor for Android (Windows/Mac). Step 1: No matter which brand of your Android device is, just connect your device to the computer with USB cable Step 2: Files on your Android have been categorized and displayed on the interface. Tick off these data types you want to recover back and click "Start" button to let the Android data recovery program scan your Huawei P10. Step 3: When the scan is finished, you can preview the scanned out data, find and mark the data you wish to restore and hit "Recover" button to save them on your personal computer without losing. It's very easy.Try it.Hope it could help you. A YouTube Guide for you: Read More: How to Recover Data from Water Damaged Android Phone or Tablet How to Use MobiKin Doctor for Android
If you want to unlock a device that's locked to our network, you'll need a Network Unlock Code (NUC). If you already have one, you can unlock your phone.
