20 Most Recent BT Synergy 6500 Cordless Phone - DECT - Silver Titanium 1 x Phone Line - Answering Machine - Caller ID - Speakerphone - Backlight Questions & Answers
2answers
Hi, my handset has lost its connection to its base, cannot see how I re-connect it. help please
Usually just re-cradle the handset for a minute. otherwise cradle and unplug for a minute, then repower the base.
4/19/2016 4:33:44 PM • BT Synergy 6500... • Answered on Apr 19, 2016
Why does my 'see who is calling mode'not work now ?
You may need to upgrade you plan to recieve Caller ID.
2/9/2016 9:53:27 PM • BT Synergy 6500... • Answered on Feb 09, 2016
I have changed the batteries on a Synergy 6500 handset but it does not charge and the display is blank. What could be the problem?
No actual idea, but check user manual, go to BT website and check there (esp FAQs). Do BT have a customer helpline?
5/17/2015 11:01:24 PM • BT Synergy 6500... • Answered on May 17, 2015
Just bought a BT6500 trio and one of the chargers has melted even though not plugged in please advise
spontaneous combustion,it will happen to you next
4/27/2015 6:52:57 PM • BT Synergy 6500... • Answered on Apr 27, 2015
Restore the beep to the dialling keys
go into the menu on the handset and find settings. scroll through the settings until you find the beep. be sure to turn it on and hit end.
1/26/2015 6:31:51 PM • BT Synergy 6500... • Answered on Jan 26, 2015
Ho w do I deal with power cut and flat battery?
As batteries go thru many charge and recharge cycles, they lose their ability to retain full charges. Time to buy a new battery.
12/8/2014 9:36:16 PM • BT Synergy 6500... • Answered on Dec 08, 2014
Why does my Phone handset says no link to base please check base?
Charge handset Make sure there are not other signals interfering with the phone (wifi router). Check to see if base and handset are on the same channel.
8/2/2014 12:31:56 PM • BT Synergy 6500... • Answered on Aug 02, 2014
OUR BT HANDSET SAYS THE LINE IS BUSY WHEN IT'S NOT. i HAVE RESET THE HANDSET USING THEINSTRUCTIONS ON LINE FOR THE BT ASPIRE
The busy signal message only indicates that the phone doesn't get a dial tone signal. This could result from a problem with the wires inside or outside the home. With some modern fiber optic systems, the modem that translates the signal back to POTS (plain old telephone system) analog could be faulty. I like to use an old corded basic phone for most diagnostics. First, try a new RJ-11 cord between the phone base and the jack. (I've seen someone use the coiled handset cord between the phone and the jack. That doesn't work.) If the new cord works, great. Otherwise, test with another phone. If the test phone has a dial tone, then the problem is with the BT system. For cordless phones, double check if the unit is getting power. Transformer bricks should get warm. If it is under warranty, contact the company. If you still don't have a dial tone, test the phone line at another jack for that number, if one is available. If other jacks work, then you have a problem with that jack or the wiring back to the incoming service. Most phone jack faceplates either secure the wires with screws or a keystone. For the first, you will need to strip the wires before securing them to the appropriate point. For the second type, you don't strip the wires. Instead you need a punch-down tool (available at most hardware stores in the low-voltage wiring section). Use https://www.lanshack.com/wire_phone_jack.aspx for the correct wire placement. If you recently had someone work on the service connection, check if all of the extension wires were connected to the correct part of the service box. If the problem isn't specific to one jack, check your incoming service box. In some cases, you can just plug in the basic phone's RJ-11 cable and listen for a dial tone. If there is no dial tone, contact your telephone company. Somewhere upstream, there is a damaged wire. For underground copper telephone wiring, the problem could be from animals chewing on the wires or someone damaging the wires while digging. Most companies should fix outside problems for free. Some will try to sell you a service upgrade instead. If you can't test the service at the box, contact the telephone company. They have the equipment to test the line. These technicians can also fix inside wiring problems for a fee. I hope this helps. Cindy Wells (Yes, I have dealt with these problems before. The service upgrade was the strangest one. They unplugged four extension wires at the start of the job. Then they lost one wire behind the siding when they finished. It took three minutes for me to find the wire and plug it back into the service box with RJ-11 jacks.)
8/24/2022 11:33:41 PM • BT Lands Phones • Answered on Aug 24, 2022
I connected a call blocker to a BT duet 600 phone and the ringer red light always stays on?
then take it back off the system
10/20/2021 7:58:07 PM • BT Lands Phones • Answered on Oct 20, 2021
BT Synergy 6500 Cordless Phone - DECT - Silver Titanium 1 x Phone Line - Answering Machine - Caller ID - Speakerphone - Backlight Logo
28 questions posted
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
BT Lands Phones
  • BT Lands Phones
Most Popular Question
ring no 2 handset
  • Lands Phones
