20 Most Recent CES Manufacturer HTC Desire 816 Questions & Answers
1. Replace "button"
2. Replace phone
Cell Phones | Answered 6 hours ago
I've the same problem i would thanks if you tell how to recover when you get the right answer
Cell Phones | Answered 9 hours ago
I have a Set 3B and only have experience with that model. Check that you have the instrument leveled with the bubble just above the display. If very far out of level, the self-leveling feature does not work and the instrument displays an error.
Also, confirm that you have indexed the vertical and horizontal encoders by spinning the scope vertically at least one full turn and horizontally at least one full turn. These are required on startup. I typically spin two turns and hear a "beep" when the index point is passed.
Another poster on Fixya says E190 means a problem with the horizontal encoder and suggests seeing a Sokkia service center.
Cell Phones | Answered Yesterday
Contact Vancity directly to inquire.
Ummm. OK. how can I reply to not make it seem like I'm suggesting that the 1 answer you got to your question came from a mentally retarded neanderthal with decades of inbreeding making up her family tree? ?? So I am going to simply point out she thinks that the digital scale you are asking about is a lawnmower, chainsaw, or another piece of machinery that is gas powered and has a safety switch for low oil causing it to not start and therefore protecting the engine from damage if u don't know that the oil is low.???? So I'm going to point out the fact that digital scales, just like most electronics, DO NOT have said "safety switch" because THEY DO NOT USE, NEED, OR REQUIRE OIL IN ORDER TO RUN. ??This is a big plus in both financial and environmental costs. (This means the upkeep on electrical devices is better for your wallet and better for the environment as far as pollution goes).?? So with that being said, have you tried changing batteries and before you put the new ones in wait 10 minutes then put new batteries in. I have seen people suggest the same thing and said it works. Also another post suggested holding the tare button while pushing mode until you see something else on the display screen. Hope this helps, and don't forget to get the right batteries for it. Make sure they are the ones that don't need oil in order for them to work properly. ????????
Pairing Bluetooth Devices
Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by Andrew... on Nov 19, 2016
Cell Phones | Answered 3 days ago
To transfer data between your phone and computer, you can try some data backup softwares, and I think it can be easier with an android assistant tool, you can save a lot of time to transfer or backup text messages, contacts, photos, and other media files like videos, music files. How to Transfer Photos Between Android Phone and Computer
Cell Phones | Answered on Jul 01, 2020
  1. Open the dial pad on the device.
  2. Dial Voicemail. Tapping the number 1 and then hitting the green phone icon at the bottom should call Voicemail.
  3. Enter a password (if there is one). Enter the password for the voicemail by tapping the number keys and then the # sign.
  4. Skip through messages. There may be multiple voicemail messages on the account. Press 9 when listening to each message to save it and move to the next one.
  5. Delete a voicemail. Press 7 on any voicemail to delete them.
If you want any information contact with hp printer support number 1 800 712 0802 HP Printer Support Phone Number HP Technical Support
Cell Phones | Answered on Jun 30, 2020
Go into call settings on your phone click your provider name and click additional settings, click caller id then in the list click hide my number.
SO WHAT THAT IS A PROBLEM ONLY A PERSON THAT DOES NOT WRITE IT DOWN FACES
Cell Phones | Answered on Jun 28, 2020
The only people that would know the answer to that would be the company that supplies your telephone service.
Cell Phones | Answered on Jun 27, 2020
For this problem contact your mobile service provider.........
Cell Phones | Answered on Jun 26, 2020
You cannot. apple doesnt allow it. If you try by malpractice, Apple will brick your phone for sure.
Cell Phones | Answered on Jun 23, 2020
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
  1. From the home screen, tap the Menu button.
  2. Tap Settings.
  3. Tap Mobile networks.
  4. Tap Access Point Names.
  5. Tap the Menu button.
  6. Tap New APN.
  7. Tap the Name field.
  8. Enter Internet, then tap OK.
CES Manufacturer HTC Desire 816 Logo
3 questions posted
Popular Products
Top CES Manufacturer Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a CES Manufacturer Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • CES Manufacturer Cell Phones
Most Popular Question
samsung galaxy 3 tab broken recover
  • Cell Phones
