20 Most Recent Celcus LED40S0913FHD 40" LCD TV 1920x1080, 50 Hz, HDTV, LED Backlight Questions & Answers
Turn volume up and the TVs volume goes back down to zero straight away everytime
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
4/12/2017 7:45:47 AM • Celcus... • Answered on Apr 12, 2017
There is no sound on our Celcus TV and the mute button has been checked
Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electro-medical.blogspot.com/
9/1/2016 8:43:01 PM • Celcus... • Answered on Sep 01, 2016
My celcus tv wont go back to wide screen
Replace the display panel at-once. Do not switch ON the set until you have replaced it. Risk of fire!!!
8/28/2016 1:57:28 PM • Celcus... • Answered on Aug 28, 2016
My celcus t.v keeps turning it self on and off,remote control has no effect.
8/22/2016 10:56:40 AM • Celcus... • Answered on Aug 22, 2016
Hi my remote wont work, how do i change channels its stuck on one channel
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean. http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
7/26/2016 10:42:10 AM • Celcus... • Answered on Jul 26, 2016
My Celcus tv keeps turning on and off on its own. I get picture and sound for about 5 seconds then turns off and does it again.
Your power board is perhaps going bad. Get to find the replacement part number for the entire board and replace
6/21/2016 10:16:59 PM • Celcus... • Answered on Jun 21, 2016
I woke up this morning and the sound has completely gone ..... Was fine last night it's plugged into sky and Xbox ....was all working fine help ?!?!?!!?
If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
6/13/2016 1:20:26 PM • Celcus... • Answered on Jun 13, 2016
Why does it have picture but no sound?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
3/27/2016 5:16:14 PM • Celcus... • Answered on Mar 27, 2016
Celcus TV codes for universal remote
0039 0223 0686. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
5/1/2015 5:29:31 AM • Celcus... • Answered on May 01, 2015
How do i get rid of the horizontal line going through the TV
Could be your display panel. check all your connections between the T-con & display panel, look specifically for corroded contacts at the panel plug, if you have that, try to clean those contacts. If that doesn't cure it you may need the display panel. This would not be cost effective unless you found a used unit with a known good panel & could purchase very inexpensively.
3/5/2015 11:13:04 PM • Celcus... • Answered on Mar 05, 2015
Change the stored programme on the my button
Do a factory reset to this set. It will wipe off all. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
12/28/2014 3:13:28 PM • Celcus... • Answered on Dec 28, 2014
0answers
How do I change the picture size?
You can change the picture size by using either the TV remote or the cable box remote (which ever you are using). Just go into the TV settings option, scroll through the different options that adjust everything from color and tint, sound, contrast, etc, and you should find one for changing the screen size (my Sony TV can be changed from normal, and wide, to wide zoom).
9/20/2014 6:40:31 PM • Celcus... • Answered on Sep 20, 2014
0answers
Celcus tv problems
Be the first to answer 8/21/2014 6:55:17 PM • Celcus... • Posted on Aug 21, 2014Be the first to answer
How can I turn mute off with controls on TV.
You should have a remote control to un-mute it.
8/10/2014 11:29:43 AM • Celcus... • Answered on Aug 10, 2014
2answers
Picture but no sound
Dear Amanda, Please check in the TV remote control whether the volume is in mute or its in low. Regards, Samy
8/10/2014 7:40:33 AM • Celcus... • Answered on Aug 10, 2014
0answers
Why does it take celcus tv three hours for power light to come on, so i can press a channel button to start watching the tv?
Sounds like back-light problem. Contact any service technician. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
7/19/2014 1:26:37 PM • Celcus... • Answered on Jul 19, 2014
Celcus tv will not play movies
Your passport is just an external hard disk. Perhaps it even contains movies, but without a PC or a media centre, capable of playing the movie formats you have on the hard disk you won't see any movie. Sometimes you just need an extra device. if you have a lot of MP4 media, ending on '.mov', '.m4v' of '.mp4', you can play them with the Apple TV. But I'm sure there are more devices capable of playing video formats.
7/16/2014 7:00:53 PM • Celcus... • Answered on Jul 16, 2014
Celcus soundbar IR profile number for Firestick
Celcus - 4146
11/22/2023 3:09:57 PM • Celcus Televison... • Answered on Nov 22, 2023
Celcus LED40S0913FHD 40" LCD TV 1920x1080, 50 Hz, HDTV, LED Backlight Logo
22 questions posted
Top Celcus Televison & Video Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Celcus Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Celcus Televison & Video
Most Popular Question
no sound our celcus tv mute button
  • Televison & Video
