20 Most Recent Vizio E550i-B2 55" LED TV 1920x1080, 120 Hz, HDTV Questions & Answers
The sound board could be faulty there could also a a loose ribbon cable problem inside of the TV. If he TV is not been turned on to mute Under the audio or either the audio settings on the TV's screen menu,and the TV's Speakers are turned on . All of the cables that have been physically connected to the TV and the input devices are fully secure. Change it to another input device and verify there is sound is coming from the TV speakers.
Vizio E550i-B2... • Answered on May 05, 2021
You can go to the Vizio site and download their manual and if that doesn't have it! You can look download a service manual from one of those sites on the web that has service manuals and that is what I did. It cost me $12 for the service manual but was helpful, somewhat!
Vizio E550i-B2... • Answered on Mar 29, 2021
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Vizio E550i-B2... • Answered on Feb 19, 2017
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Vizio E550i-B2... • Answered on Feb 16, 2017
If you can see an image with a flashlight and you can control the tv with the remote then the main board is not the problem. You've replaced the LED driver board, so that leaves the LED strips inside the LCD panel as the likely problem.
Vizio E550i-B2... • Answered on Feb 12, 2017
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Vizio E550i-B2... • Answered on Jan 17, 2017
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Vizio E550i-B2... • Answered on Dec 31, 2016
What is the part number that you are replacing each time
Vizio E550i-B2... • Answered on Dec 29, 2016
Vizio E550i-B2... • Answered on Dec 18, 2016
http://www.shopjimmy.com/lg-lc550dug-jfr1-led-strips-12-strips.htm Call these guys. They can assist you. What Vizio is saying is the LED strips are mounted in the LCD panel and cannot be replaced.
Vizio E550i-B2... • Answered on Oct 09, 2016
My dear follow the way shown in the pic
Vizio E550i-B2... • Answered on Jul 29, 2016
One or more of the LED backlight strips behind the LCD have failed. Difficult and sometimes expensive to fix.
Vizio E550i-B2... • Answered on Jul 19, 2016
Vizio E550i-B2 55" LED TV 1920x1080, 120 Hz, HDTV Logo
33 questions posted
Top Vizio Televison & Video Experts
Paul Bade
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio e550 b2
  • Televison & Video
