20 Most Recent Jabra Solemate Mini Portable Bluetooth Speaker Questions & Answers
Turn off headset, press and hold power button till light flashes blue and red continously.
Release power button and press it twice. You will hear a Chinese voice prompt.
Press twice again to hear English voice prompt.
Press and hold till it turns off.
Turn it back on and connect to phone.
Jabra Solemate... | Answered on Jul 05, 2017
Hi replace battery .Check out E/BAY THERE R SOME FOR SALE...,COST APROX $25-00 Cheers
Jabra Audio... | Answered on Feb 13, 2017
It is radio controlled and sets itself.
Audio Players &... | Answered 3 days ago
This is a very common issue. Unplug the mini power jack the thing with the cord. Look inside the chargers hole on the jam box and then take a knife to gently bend the tab back towards the middle or even lower. Be careful when you are re plugging into the power into the socket. The socket tab and the mini plug must meet .
Audio Players &... | Answered on Aug 03, 2020
The AUX connection is what the Line In connection used to be called and generally has a medium impedance and a sensitivity of upwards of 800 mv, often 1 to 1.5 volts, being the typical output of a tuner or tape deck.
Details of this is usually found in the user manual - good matching is repaid in better quality sound and reduced interference.
Audio Players &... | Answered on Aug 02, 2020
Press the buttons of your mystery appliance in the correct order.
OR
You could Google
make model manual
Audio Players &... | Answered on Aug 01, 2020
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Audio Players &... | Answered on Jul 30, 2020
Jabra Solemate Mini Portable Bluetooth Speaker Logo
1 questions posted
Top Jabra Audio Players & Recorders Experts
Tom Chichester
Harrie
Martin Doyle
Martin Doyle
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Audio Players & Recorders
Most Popular Question
change language jabra mini bluetooth
  • Audio Players & Recorders
