20 Most Recent Blaupunkt BLA32/147 32" LED TV 1920x1080, 50 Hz, Freeview, HDTV Questions & Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Blaupunkt... • Answered on Apr 19, 2020
Visit this site to download its manual. It will have all details. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. https://remotesearch.blogspot.com/ https://electrohelponline.blogspot.com/ https://electronicshelponline.blogspot.com/
0057 0060 0113 0177 0221 Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. https://remotesearch.blogspot.com/ https://electrohelponline.blogspot.com/ https://electronicshelponline.blogspot.com/
Refer the user manuals to both the devices.
Blaupunkt... • Answered on Nov 21, 2017
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Blaupunkt... • Answered on Sep 04, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://electro-medical.blogspot.com/
Blaupunkt... • Answered on Jul 31, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Blaupunkt... • Answered on Apr 23, 2016
Roy, change your cable, must be faulty and not giving a signal to TV. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Blaupunkt... • Answered on Mar 17, 2016
my tv says no signal - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../my-tv-says-no-signal/td.../13296...
Jun 28, 2012 - My tv says no signal. ... Start here. Sign in or Sign up ... Plug in the TVfirst, then the cable box, turn on the TV, then turn on the cable box.
Computer turns on, monitor says "no signal" [Solved] - CCM
ccm.net > Forum > Windows
Mar 10, 2013 - I recently had problems of it randomly turning off at any time, i could be working ... Then i decided to take out the wireless B PCI card, then the computer booted! ... tycoonXD) and i needed to start my computer up again cause it didn'tworkwell, ... i've tried many things, turned of the powerbutton waited for 39 ...Missing: blaupunkt
Blaupunkt... • Answered on Jan 05, 2016
If audio is good, and picture is absent, back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Blaupunkt... • Answered on Nov 14, 2015
032,033,029. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
Blaupunkt... • Answered on May 22, 2015
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Blaupunkt... • Answered on Feb 15, 2015
The problem post of yours' is difficult to understand. Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Blaupunkt... • Answered on Dec 17, 2014
If you tap "gently" on the front screen do you see whiteish color? If no you have a problem with the set. probable power supply issue. If you do then press menu. If you don't see the menu on screen, probable control board issue or lvds board. Time for a tech.
Blaupunkt... • Answered on Jul 29, 2014
Time for new at walmart. This time buy a fan to keep it cool. Tv will fail from heat earlier
Blaupunkt... • Answered on Feb 07, 2021
Blaupunkt BLA32/147 32" LED TV 1920x1080, 50 Hz, Freeview, HDTV Logo
Popular Tags
25 questions posted
Popular Products
Top Blaupunkt Televison & Video Experts
Vernon Taylor
ADMIN Canada
ADMIN Canada
 Mikey
Mikey
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Blaupunkt Televison & Video
Most Popular Question
receive hd channels
  • Televison & Video
