20 Most Recent
Veho VFS-008 Smartfix Film Scanner USB 2.0, PC/Mac Questions & Answers
Computer does not recognise Scanner -- why not?
How old is the scanner? did you read for what Windows version it was made in the first place?
If it is for an older OS then Windows7 and you are using Windows 7 or higher, you ran out of luck.
Always first install the software that came with the device. The driver needed for the device is supposed to be on the install disk.
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems.
So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
X86 negative scanner. how do I upgrade from Windows XP?
U only time to upgrade is when and if your computer is not working for you. If all is fine, upgrading can be very problematic for most users and is not recommended. You will also run into driver issues. But if you must upgrade go ahead - you have been forewarned and must be ready for the consequences.
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
How to change tax rate on spl-290 calculator
* Press *N/C/CE *****n* Enter 200* Press the TAX+ *****n* The display will sh*w the t*tal price TAX+ 210* Press the TAX+ *****n again* The display will sh*w the tax am*unt TAX 10* *r the price after tax is $58.5, what is the pre-tax price and tax am*unt:* Press *N/C/CE *****n* Enter 58.5* Press the TAX- *****n* The display will sh*w the pre-tax price TAX- 55.72* Press the TAX- *****n again* The display will sh*w the tax am*unt TAX 2.78
My conlog is showing minus - 11.06 kwh
You mentioned a reading of minus 11.06 kWh. Here's what it means:
Remember that this is a prepaid meter, so the negative value suggests that you've used more energy than what was prepaid
The meter has consumed 11.06 kilowatt-hours (kWh) more energy than it has generated or received.
This negative value indicates that more energy was used than supplied during the specified period.
LED Indicator:
The meter has an LED light that flashes when electricity is consumed.
When you use electricity, the meter balance decreases, and the LED light provides a visual indication of energy flow.
Plz tell me error code 21 how to fix it for ultrasonic comfort 400 nebulizsr
As you know, this is a medical device. I suggest you consult a medical professional about it as it affects your treatment. The device is Japanese in origin. The instruction manuals I encounter are written in Japanese. That may or may not prove to be an impediment to you contacting the company yourself for guidance. I am reluctant to advise you about the equipment as my guidance would be very, very general and your health is much too important for trial and error. A low battery can generate error messages. Turning it off, unplugging it, waiting a few minutes, plugging it back in and turning it on might clear the problem. Some nebulizers have a reset button.; I can't say being unable to read the manual readily. Assuring all its parts are assembled correctly is of course worth doing. The company: Koushin Industries, Inc. (Japan):
Address: 1000-1, Hirakata, Ageo, Saitama, 362-0059, Japan.
Phone: You can reach them at the provided address.
Website: Visit their website for more information: Koushin Industries, Inc. However, I find the information there to be in Japanese. Again, I suggest you consult a medical professional.
