20 Most Recent HEWLETT-PACKARD Envy 5530 built-in WiFi HP Thermal Inkjet eAll-in-One Color Printer Questions & Answers
check printer settings on the printer. Also check settings in windows printer settings. Also check settings before each print good luck.
HEWLETT-PACKARD... | Answered on Feb 09, 2018
"?" on the right of the screen is about helpful instructions.
When you touch the ? , the printer display should show up some helpful instructions.
If the printer does not respond to press the ?, then try the below steps.
> Remove all the ink cartridges
> while the printer is ON, uplug the power cord from back of the printer.
> wait for 60 seconds. Plug in the power cord to the printer.
> Install ink cartridges when prompted.
HEWLETT-PACKARD... | Answered on Feb 25, 2015
This video explains how to troubleshoot when the image is not turning out the way you expect.
HEWLETT-PACKARD... | Answered on Dec 04, 2014
Please download and run HP Print and Scan Doctor from www.hp.com/go/tools
Regards,
HEWLETT-PACKARD... | Answered on Apr 23, 2014
If you haven't tried this yet..on your print page there's a task bar that prompts you to choose your printer..make sure you choose the printer your using and then simply click PRINT..
HEWLETT-PACKARD... | Answered on Apr 20, 2014
Try a different outlet and different power cord.
HEWLETT-PACKARD... | Answered on Sep 26, 2017
No doubt the feed rollers are worn.
HEWLETT-PACKARD... | Answered on Sep 22, 2017
it sounds like your collection assembly is full. this is not something you can do anything about. it must be replaced and it will be costly. you are probly better off to replace it
HEWLETT-PACKARD... | Answered on Aug 02, 2017
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
HEWLETT-PACKARD... | Answered on Mar 01, 2015
Turn off. Reseat the memory. Restart. Error recurs, uodate the firmware
HEWLETT-PACKARD... | Answered on Feb 06, 2015
Should be 1111
HEWLETT-PACKARD... | Answered on Feb 02, 2015
What model? Connector on the outside or on the mainboard? If on the mainboard, replace it. If on the front, you should be able to just replace the connector cable and/or mounting.
make sure you have a phone line plugged in correctly (into the in plug) and set the printer / fax to recieve auto. Do not pick up the phone while recieving the fax, If thei does not work, check your setting in the software.
HEWLETT-PACKARD... | Answered on Dec 29, 2014
If IT SHOWS the HP LOGO AND NEVER COMPLETE THE INITIALIZATION; it can be FORMATTER BOARD (rplace it), could TRY TO UPDATE THE FIRMWARE AT HP SITE.
HEWLETT-PACKARD... | Answered on Dec 11, 2014
Go to this web site:www.feedroller.com
HEWLETT-PACKARD... | Answered on Nov 30, 2014
Please click An Ink System Error Code Displays on the Front Panel to access the steps that should resolve the issue.
If issue still exists, then the printer need to be serviced.
HEWLETT-PACKARD Envy 5530 built-in WiFi HP Thermal Inkjet eAll-in-One Color Printer Logo
7 questions posted
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
InkJet HEWLETT-PACKARD
  • InkJet HEWLETT-PACKARD
Most Popular Question
double side printon hp5530 when default
  • Office Equipment & Supplies
