20 Most Recent
PfaFF Sliding Buttonhole Foot 98-694882-00 Questions & Answers
How do you access the top of a Pfaff 1020 sewing machine?
To access the top of a Pfaff 1020 sewing machine, you will need to remove the top cover by unscrewing the screws located on the back of the machine. Once the screws are removed, the top cover can be lifted off to access the internal components.
Display shows battery on my pfaff anniversary edition
For a 7550, this has been noted, AND also, if batteries show leak or any corrosion, clean only with mild soap, dish, do not use acetone, alcohol, any aggressive such as these can damage plated contacts.
How do I change the battery in my PFAFF 7550 creative sewing machine?
Switch on the sewing mahine to avoid deleting the memories during the battery change. Tilt the machine over backwards. A battery compartment is installed i the base. Using a screwdriver (as a lever, not to unscrew anything), pry up/off the cover. Take out the batteries. Insert new batteries with the "+" side facing upward. Replace the cover -- hinges should engage in the lower recess; the cover should snap in place. Use heavy duty batteries, such as Duracell. Battery size is AA
Pfaff 7550 creative only sewing in zig zag stitch.
It sounds like your Pfaff 7550 Creative may be experiencing a hardware-related issue. To diagnose the problem, try resetting the machine by unplugging the power cord and waiting 10 minutes before plugging it back in. If the problem persists, then it is likely that the machine's control circuit board may have become damaged and will need to be replaced. Additionally, you should also check that the machine is receiving power by testing the power cord, power switch, and the foot pedal. If all of these components are working correctly, then the control circuit board will need to be replaced. If you need further assistance, you can consult a professional Pfaff technician for diagnosis and repair.
Where do I find replacement screws for a Pfaff 130
A local sewing machine center will have your screw if not exactly they will have a similar size and pitch of the screw threads. 99% they will have something similar even though it's not the same brand.
My pfaff 7570's display is not working
what are the symptoms you can see in your machine.?
1. check power cable from plug point.
2.if you can open your machine, check display wire loose contact or not.
