20 Most Recent
Smeg Opera A2PY-8 Stainless Steel 1000 mm Dual Fuel Range Cooker 60 l 27 l, A Energy Rating Questions & Answers
My Smeg gas oven lights up when I press the knob to light but as soon as I release the knob the flame dies?
Question edited for clarity.
The thermocouple safely device needs replacing. It's job is to make sure there is a good pilot flame before opening the main burner valve. When they fail, the flame goes out. You can try holding the knob longer, or just call for service and have it replaced. It is a gas appliance so should only be worked on by a gas certified technician. It is a fast job, in and out in 30 minutes, so call out plus the part.
OK for smeg gas stove circuit wiring diagram mode3 C9GGSSA-1
As an AI language model, I do not have access to specific product information or wiring diagrams. It is important to obtain the correct wiring diagram for your specific model of gas stove to ensure proper and safe installation. I recommend consulting the user manual or contacting the manufacturer or a licensed electrician for assistance.
Smeg gas hob, 2 burners have very low flame
If two burners on your Smeg SR275XGH2 gas hob have a very low flame, it may indicate a problem with the burners or the gas supply. Here are some steps you can try to fix the problem:
- Check the gas supply: Make sure that the gas supply to the hob is properly connected and turned on. If the gas supply is off or disconnected, the burners may not function properly.
- Check the burners: Check the burners for any visible damage or blockages that may be causing the low flame. Make sure the burners are clean and free of any debris or foreign objects.
- Check the gas pressure: Make sure that the gas pressure to the hob is set correctly. If the gas pressure is too low, the burners may not function properly.
- Check the connection: Make sure that the connection between the hob and the gas supply is secure and not damaged. If the connection is damaged, it may cause the burners to function improperly.
- Contact technical support: If the above steps do not help, you may need to contact Smeg or a technical support team for further assistance. They will be able to diagnose the problem and provide you with the necessary support.
It is also a good idea to check the documentation or manual that came with the hob for any troubleshooting tips or recommendations.
Smeg range cooker with induction hob e4
Hope this helps!
The issue is that the control board requires reconfiguration.
Firstly switch off the appliance and disconnect from the mains.
Reconnect and Press and Hold the Minus key '-'
While holding the minus key press keys 1 through 4 in turn within 4 seconds. Each key press will give an audible beep.
Once done you should get a 'C' displayed for each ring element.
Now place a pan of water on one element. Press the Plus key '+' next to the element ring and wait for the 'C' to change to '-'.
Repeat that for each element and once complete the appliance will switch off.
Reconfiguration is now complete and you can use the appliance as normal.
