20 Most Recent Emerson LF320EM4 32" 720p 60Hz Class LED HDTV 23871273 Questions & Answers
Tv went off will not come back on why
  • No power to outlet (reset breaker to that area of the house)
  • Power supply in the TV (repair or replace TV)
  • Unplugged (plug it back in)
  • Power cord chewed through by favorite pet (buy a new cord, kiss the pet)
10/21/2020 4:15:38 PM • Emerson LF320EM4... • Answered on Oct 21, 2020
TV WONT POWER ON
Hi does the TV have any standby light etc, if so power off at the wall and leave for 1 minute the power back on and watch the standby LED it may or may not blink try to power on if the light blinks this may be a fault code and you can search this up with the model number.
4/8/2015 2:49:13 PM • Emerson LF320EM4... • Answered on Apr 08, 2015
0answers
2answers
32" scene picture is 19" rest the scene is black
As per the operator manual in the case of the picture not showing up correctly, begin by pressing the "PICTURE SIZE" button several times to cycle through the various size options (sounds like you have tried this though). Next, press the power button first to see if it fixes the issue... if not, then press this sequence of buttoms on the remote control (6 buttons in this sequence): "SLEEP", "PICTURE SIZE", "[right arrow]", "[up arrow]", "[down arrow]", "[pwr button]". This restores the default screen size settings. I am not sure how you are using your monitor (TV, HDMI, Composite, PC Monitor, etc.. ). That would be very helpful. If this does not resolve the issue, I would suggest downloading the service manual from this link to work through the advanced troubleshooting flowchart... They point to a reinitialization of the basic functions (reset the TV to factory defaults) through the initialization process. I have worked on a number of this model, and have almost always found it is settings which have been inadvertantly mis-adjusted while tweaking preferences or the last settings of the operation since it will always go back to the last way it was setup when you power it up (no matter what modality was in use last time.. eg. 480i in PC or DVD operation changed to HDTV next time). Remember the HD 16:9 screen is nearly twice as long as the old 4:3 screens, as well as having nearly twice the vertical pixels... Thisis what it sounds like in your case with the 19" screen to me.. Let me know if this helps... Service Manual: http://www.buyphilipsparts.com/shop/research_new/MAG/sm/32ME303V_F7.pdf Operator Manual: http://www.emersonaudiovideo.com/product/product.php?id=649
10/12/2014 10:37:59 PM • Emerson LF320EM4... • Answered on Oct 12, 2014
How to make emerson lf20em4 play sound trough headphones only?
To turn off TV speakers, see page 23 of the Owner's Manual downloadable here... http://www.emersonaudiovideo.com/support/download.php
8/7/2014 11:24:19 PM • Emerson LF320EM4... • Answered on Aug 07, 2014
Why tv wont turn on?
You can download and "File/Save As" the manual to your Documents folder here... http://www.emersonaudiovideo.com/support/download.php
7/20/2014 3:58:36 PM • Emerson LF320EM4... • Answered on Jul 20, 2014
How do i flip the picture display on emerson lf320em4?
When in file viewer mode you can rotate pictures, this is in the manual and may be the cause.
5/6/2014 6:16:12 PM • Emerson LF320EM4... • Answered on May 06, 2014
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors - Flickering screen - Screen image disappears after several seconds - Dim screen - Slow start - Power LED on, but no picture - Unusual colors and/or lines The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad. If they appear bulged on top, then they need to be replaced. New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years. Check the cables, connectors and connections. Take it to a repair shop.
5/3/2014 4:59:38 AM • Emerson LF320EM4... • Answered on May 03, 2014
Emerson LF320EM4F 32" 720p 60hz LED HDTV
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
1/30/2014 4:35:44 PM • Emerson LF320EM4... • Answered on Jan 30, 2014
0answers
EMERSON LE220EM3
Be the first to answer 3/4/2019 8:47:34 AM • Emerson... • Posted on Mar 04, 2019Be the first to answer
0answers
My Emerson tv will not download Netflix etc..it just keeps buffering..not cable company as I can get them on tablets
How does it connect? If it is wifi, what is the rating of the wifi
8/2/2018 11:58:27 PM • Emerson... • Answered on Aug 02, 2018
How do i get the sound back to my 32' emerson flat screen tv plz ANSWER ASAAP
Make sure if you are using the RCA connectors they are the red, yellow, white. Connecters that the red and white are connected from your device to the tv. Also if you are using a HDMI or something else. Maybe try turning up the power on your device. If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
3/17/2018 6:04:17 PM • Emerson... • Answered on Mar 17, 2018
Emerson LF320EM4 32" 720p 60Hz Class LED HDTV 23871273 Logo
Popular Tags
13 questions posted
Top Emerson Computers & Internet Experts
ray gallant
Are you an Emerson Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Computers & Internet
Most Popular Question
32 scene picture 19 rest scene black
  • Computers & Internet
