20 Most Recent
Tagital Taital TM 7 Inch Dual Core Tablet PC Android 4.2 Allwinner A20 1.2hz Dual Camera Questions & Answers
FACTORY RESET
Does this tablet have a volume control button? If so this is the reset instructions
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen. Select wipe data / factory reset with the volume keys and tap the Power button to activate it. Select Yes - erase all user data with the volume buttons and tap Power.
How to remove battery in TAGITAL T7K Tablet?
What you need to know before removing the battery in a TAGITAL T7K Tablet
Before you remove the battery in your TAGITAL T7K Tablet, there are a few things you should know. First, make sure the device is powered off.
If it's not, you can hold down the power button for a few seconds to turn it off. Once the device is powered off, you'll need to remove the back cover.
There are typically small tabs or screws that need to be removed in order to take off the back cover.
The steps to remove the battery in a TAGITAL T7K Tablet
Once you've removed the back cover, you should see the battery. It will be connected to the device with a small connector.
Gently disconnect the battery from the device and then remove it. You may need to use a small tool, like a paperclip, to help disconnect the battery.
Once the battery is removed, you can put the back cover back on and screw or snap it into place.
Can a tablet that will not charge be fixed easily?
it will be the battery - the batteries can only be charged a certain number of times
cost of battery approximately $25 USD plus shipping costs
moderate difficulty in opening tablet see below video
https://www.ifixit.com/Guide/Tagital+T10+Battery+Replacement/72817
Had a different tablet that was a kids tablet
was told by a seller/ retailer that it was impossible to replace the battery.
However I figured out how to open up tablet and purchased a replacement battery on line and fixed tablet.
hardest part was figuring how to open tablet ...
