20 Most Recent Toshiba SD-P1200 Portable DVD Player Questions & Answers
I have the same problem with my dopo td1010 i used it on the city bus one day then put it in the case as i was walking home and took it out when i got home turned it on set it on the table went to us the broom came back and the screen was flipped upside down and backwards. I have had it for a year and a half with the screen like this and cant contact customer service because they wont pick up.
Toshiba SD-P1200... | Answered on Jan 01, 2014
just happened to me, phoned customer support and solution is to press the Ctrl key and Alt key and Up arrow together and it should solve the problem
Toshiba SD-P1200... | Answered on Jul 02, 2013
Right click on the desktop
Select Graphic Properties
When the window pops up, just change the rotation to Normal (Yes, I know you might need to stand on your head to do that :) )
Toshiba SD-P1200... | Answered on Feb 24, 2013
Press CTRL ALT AND THE UP KEY together
Toshiba SD-P1200... | Answered on Sep 07, 2012
try tacking the computer back,, all programs, accesories, systum tools, styum restore
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.Restore by pressing Ctrl-Alt plus the up arrow key.ALSOTo change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.Some computers do not have this function.
Toshiba SD-P1200... | Answered on Jul 04, 2012
hello, the screen can be replace with a new one of the same size and model.
Good luck...
Toshiba SD-P1200... | Answered on May 21, 2010
go into settings on tv see if one for video or change setting also check player for setting
Toshiba... | Answered Yesterday
The most common reason for a TV to display a blue screen with no picture is because the source device has not been set to the proper mode.
If you are using a cable or satellite set-top box, ensure that it is turned on and set to an active station. If the set-top box is connected to the television using a coaxial cable, then the television should be set to Channel 3 or 4 to receive the signal.
If you are using a VCR that is turned on, but not playing a tape and not tuned to a receivable channel, then a blue screen will be displayed on the TV. To resolve this, turn off the VCR or tune it to a receivable channel. If a cable or satellite set-top box is connected to the VCR using a coaxial cable, then the VCR should normally be set to Channel 3 or 4 to receive the signal.
Toshiba... | Answered on Feb 20, 2020
https://www.google.com/search?sxsrf=ACYBGNTVGZctZ8KkQV0t4ebQ3lNunwx-UQ%3A1581955911674&source=hp&ei=R7tKXqvkJobqav-tkkg&q=Unlock+pin+on+toshiba+22D1333B&oq=Unlock+pin+on+toshiba+22D1333B&gs_l=psy-ab.3...74105.74105..75007...3.0..0.290.290.2-1......0....2j1..gws-wiz.....10..35i362i39.PylHZy-v9vE&ved=0ahUKEwjro6eB_djnAhUGtRoKHf-WBAkQ4dUDCAU&uact=5#kpvalbx=_UsVKXvWjEcySlwTTm6HgCA29
  1. Using the remote control, press the following button sequence in a timely fashion: 1 , 2, 3, 4 (This will release the "Retail Lock" mode)
  2. Enter the User Menu and locate Reset Factory Defaults for the subject model.
  3. Complete the Factory Defaults reset.
  4. Power on the TV.
You can reset and eliminate the lock on some televisions without the remote, using a few tactics. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television.
Toshiba... | Answered on Feb 17, 2020
Save your money by having your TV repaired by professional technicians.
Toshiba... | Answered on Feb 14, 2020
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Toshiba... | Answered on Feb 12, 2020
If u need to see online on usinig internet on your pc it is easy. For solution check the below link >>> http://w.atch.me/3qny1s
Toshiba... | Answered on Feb 05, 2020
Toshiba SD-P1200 Portable DVD Player Logo
Popular Tags
18 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
picture reversed upside down
  • Televison & Video
