20 Most Recent
DeLonghi Die-Cast Pump Espresso Cappuccino Maker EC860, Silver Questions & Answers
Delonghi Ecam 23.450S heating up please wait
'heating up please wait...' and that's it, suggests a fault with either a sensor or a control board... and in today's market, who could ever guess which?
I'm sorry this is far more philosophical than technical. I really hate to say this. Still, if any half-way modern appliance has given you 15 years' service, what more would you have expected?
Traditionally, you would have taken any faulty gizmo to a local repair expert, who would have fixed it for a charge greatly less than any replacement cost.
Today, it's almost inconceivable that the cost of even diagnosing, let alone fixing any fault would be comparable to the cost of replacing (whatever) with a new one.
The error code close door does not go off even if the service door was closed on DeLonghi Magnifica coffee machine
According to the De'Longhi UK website, the error message "Close Door" could be caused by two issues :
The brewing unit is not installed properly in the unit. You can try turning the unit off, remove and reinstall the brew unit, and then turn the unit back on to see if it reset itself.
The latch on the service door has coffee build up and is restricted from moving freely. Please clean the latch area and make sure the door closes.
If neither of these solutions work, you may need to contact DeLonghi support for further assistance.
We have a De Longhi coffee grinder KG100. The
First you pry the timer knob off and remove hopper, under the machine there a 4 tabs, using a small screwdriver pry those until the casing slides off.
Unscrew the nut holding the timer and take out timer, unplug the terminals, replace or try and repair.
Warning there a cogs and springs in there, i was unsuccessful.
Esam6700 hot water spout and milk frother not working:
Based on the information provided, it is possible that there is an issue with the machine's internal circuitry or wiring. It could also be a problem with the control board or the sensors that detect the presence of the milk jug or hot water spout.
One possible solution is to try resetting the machine to its default settings. To do this, turn off the machine and unplug it from the power source. Wait for a few minutes before plugging it back in and turning it on again. This may help reset any internal settings that could be causing the issue.
If resetting the machine does not work, it may be necessary to have it serviced by a professional technician. They can diagnose and repair any underlying issues with the machine's components.
It is also worth noting that regular maintenance and cleaning of the milk frother and hot water spout can help prevent issues from occurring in the first place. Be sure to follow the manufacturer's instructions for cleaning and descaling these parts of the machine.
Overall, if the issue persists, it is recommended to contact Delonghi customer support or a certified technician for further assistance.
De'longhi Eletta coffee machine Steam doesn't come out from the spout?
There is no video? You can only link it to the post if it is on YouTube, or you can put a text link to a place like DropBox.
These machines need professional service every 6 to 12 months, but they don't tell you that when you buy one! The appears to be a few different models of Eletta, they seem to be a series. I see one with a milk tank on the left and another that makes two cups with a flat front. If it is leaking from the milk steam spout, they need soaking in a milk enzyme cleaner because the milk gets baked on inside the tube. They also have o-ring seals when one part joins another.
https://www.google.com/search?q=de%27longhi+eletta+steam+leaking+water
I replaced the water sensor and the magnet is flooding properly in my Delonghi Magnifica XS, but the fill tank light is not litnihg ON when the water level is low. What can be the problem?
If you have already replaced the water sensor and the magnet is functioning properly, there are a few other potential causes for the fill tank light not turning on when the water level is low in your Delonghi Magnifica XS.
- Faulty sensor connection: Check that the sensor connection is clean and connected properly. Make sure there are no bent pins and that it is seated correctly in its socket.
- Faulty control board: The issue may be with the control board, which could be preventing the fill tank light from turning on even when the water level is low. You may need to replace the control board to fix this issue.
- Faulty wiring: Check the wiring for any signs of wear or damage. If you find any, you may need to replace the wiring to fix the issue.
If you have tried these steps and the fill tank light still doesn't turn on, you may want to contact a professional technician for further diagnosis and repair.
Delonghi dynamica infuser stuck
If the infuser on your DeLonghi Dynamica espresso machine is stuck, there are a few things you can try to release it:
- Turn off the machine and unplug it from the power source.
- Wait a few minutes to allow the machine to cool down.
- Press the infuser release button while gently pulling on the infuser.
- If that doesn't work, try gently pushing the infuser up and down while pressing the release button.
- If the infuser still won't budge, try applying some food-grade lubricant to the infuser and/or the infuser chamber.
- If none of these steps work, it's best to contact DeLonghi customer support or take the machine to a professional repair shop.
