20 Most Recent Toshiba RD-XS32 DVD Recorder Questions & Answers
If the internal fuse is okay, then what you got here is a bad power supply. Many power supply's do die with the internal fuse intact what happends is the High voltage tranformer or relay goes out on you causing this to happed, Best thing to do is replace the unit becuase a new power supply would cost you more then the unit new. Let me know if you have any question.
please do not forget to rate. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Toshiba RD-XS32... • Answered on Apr 02, 2016
You must use the input setting and select dvd. Thanks.
Toshiba RD-XS32... • Answered on Sep 02, 2014
contact to nearest service center
Toshiba RD-XS32... • Answered on Aug 04, 2013
TENGO UN TOSHIBA DVD RECORDER Y EN LA PANTALLA TIENE UN ERROR ER7071, COMO PUEDO ARREGLARLO?
Toshiba RD-XS32... • Answered on Jul 26, 2013
I fixed it by 1. delete all on HD drive (a function described at the end of your manual) 2. turn off your recorder 3. turn on your recorder 4. now should E49 not be vivible and recording function again
Toshiba RD-XS32... • Answered on Mar 31, 2013
It is confusing to many people this function, but not impossible to investigate (perhaps experiment with some of the functions). You can get a copy of the INSTALLATION GUIDE (if you don't have a copy for any reason) from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/RD-XS32SU_Inst_E.pdf
and if you don't have a copy of the original OWNER'S MANUAL, you can also download that from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/rd-xs32_om_e.pdf
(copy and paste into your browser if required - these are both FREE documents)
(Page 48 of the installation guide (not the owner's manual) tells you about IR CODE setup option using remote - read that first if you like, then try your recorder).
Hopefully this helps you a tiny bit.
Toshiba RD-XS32... • Answered on Mar 24, 2011
This is one of the hardest problems to solve. The first thing you can do is run a lens cleaner throught the machine. There is a distinct possiblility that there is a spec of dust on the lens. What I've done with a couple of machines I've come across is to perform a little bit of "percussive maintenance" by rapping the machine with your hand as it is trying to read the blank disk. Both times this has worked for me. This is unconventional advice, but works sometimes. Beyond that, the machine will need to be taken in for service.
Toshiba RD-XS32... • Answered on Oct 13, 2010
This is most probably an error message telling you that the Hard Drive in the unit has become corrupted. Below are two links first is to help you do it. The second is the Service manual you will need.
http://www.normediasolutions.com/forum/viewforum.php?f=12
http://www.nodevice.com/manual/newmans/toshiba/rdxs32_service_manual1pdf/get31539.html
Toshiba RD-XS32... • Answered on Mar 04, 2010
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Toshiba RD-XS32... • Answered on Jul 23, 2009
Toshiba RD-XS32 DVD Recorder Logo
42 questions posted
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba rd xs27ke
  • Televison & Video
