20 Most Recent Honeywell HZ7040 Compact Heater Questions & Answers
This sounds like a theromostat problem. If you're NOT still under warranty you should at least open the heater and look for the theromostat. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace. Good luck!
Honeywell HZ7040... | Answered on Dec 09, 2010
Off position then reverse batteries polarities and wait 5 sec. Then place new batteries back to normal position.
Honeywell... | Answered on Dec 11, 2020
There could be some problem related to battery replacement.
Honeywell... | Answered on Dec 01, 2020
Honeywell T6575D1009 - Digital Fan Coil Thermostat
www.supplyhouse.com > Honeywell-T6575D1009-Dig...
Honeywell T6575D1009 - Digital Fan Coil Thermostat; 4 pipe Auto Heat/Cool changeover, 3 speed fan with On-Auto Fan switch - Overview T6570 Series Digital ...
Honeywell T6575D1009 thermostat
www.ontimedirect.com > t6575d1009-thermostat
Honeywell T6575D1009 Thermostat. This item has been replaced by TB6575A1000, which is a functional replacement. See the suggested products field for a ...
T6575D1009 Honeywell Electric Thermostat-NECC
necc-controls.com > t6575d1009-honeywell-commercial
Honeywell T6575D1009 NECC offers Fan Coil T/S Auto C/O.
Honeywell T6575D1009 120v Thermostat ' Heating, Cooling ...
www.kijiji.ca > ... > Home Renovation Materials
Send me any offer. Delivery and instal available for a small fee. Slight used, works and good condition. Digital Fan Coil Thermostat; 4 pipe Auto Heat/Cool ...
Honeywell, Inc. T6575D1009 T6570 Series Digital Fan-Coil ...
controlscentral.com > tabid > ProductID > honeywell-t6...
T6575D1009 T6575D1009, Honeywell, Inc., Digital Fan-Coil Thermostat/2 or 4 pipe heat/cool Digital Fan-Coil Thermostat/2 or 4 pipe heat/cool.
Honeywell... | Answered on Nov 19, 2020
It means the thermostat is set for cooling vs. heating
Honeywell... | Answered on Oct 30, 2020
Actually the message is Bat Low meaning the internal batteries need to be replaced.
1. Incorrect battery installation
2. Defective batteries
3. Thermostat failure
Request the manual directly from Honeywell.
Request the diagram directly from Honeywell.
Contact Honeywell directly to request the manual.
don't know but honeywell technical support may know
https://www.honeywellstore.com/customer-service/contact-us.htm
check if it has a safety switch in the base as it may not be making contact with the surface the fan is sitting on.
It has a timer maybe cause ?
if not in usa then go to honeywell in your country and then look for help at bottom of web site.
Honeywell... | Answered on Jun 01, 2020
https://www.youtube.com/watch?v=RtgN-tM9Al0
Honeywell... | Answered on May 03, 2020
Robert Shaw 9500 manual
Honeywell... | Answered on Apr 29, 2020
Honeywell HZ7040 Compact Heater Logo
1 questions posted
Top Honeywell Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Heating & Cooling
Most Popular Question
honeywell hz7040 shuts off after few
  • Heating & Cooling
