20 Most Recent
RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black Questions & Answers
How to turn off speakers on rca tv
Cut the wires off an old headphone jack and put the jack in the headphone port at the back of the tv. It should turn off the speakers on the TV.
7/20/2019 5:05:28 PM •
RCA...
Answered
on Jul 20, 2019
Lcd tv vertical line
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
7/27/2016 2:36:49 AM •
RCA...
Answered
on Jul 27, 2016
No Digital Channels Detected
Jason, good you have narrowed down the problem. So tv 1 does not detect channels. Re-connet and try making sure all cables are properly connected.
12/11/2014 8:27:11 PM •
RCA...
Answered
on Dec 11, 2014
Digital channels are not working
If your TV is connected to a "cable" box, e.g. you're using cable TV ... then it is the cable TV box that determines what you can get (based on your cable subscription). Yes, I know that some cable TV and satellite TV service providers will only deliver HD digital channels when you pay an additional (monthly) fee for HD digital channels.
If you plug the cable directly into your TV (i.e. not use the cable box), you may be able to do a channel scan on your TV, to pick up the digital channels ... but you will loose the convenience of using the features that your cable box provides .
3/3/2014 6:27:25 PM •
RCA...
Answered
on Mar 03, 2014
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
