20 Most Recent
Toshiba TP50F50/51 50" Rear Projection Television Questions & Answers
Television will no come on. Makes noise and only
If it is a tp50f51 you may have a shorted convergence IC; this set uses two STK392-110 convergence IC chips---only way to know is to unsolder both of them and see if set comes on; if it does---the convergence will be out the window, but you will know what is causing the trouble---both can be purchased on Ebay for less then 12 dollars plus shipping---if you need direct help contact me---
[email protected]
8/15/2009 5:12:39 AM •
Toshiba...
Answered
on Aug 15, 2009
Blinking led light on Toshiba
wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
12/5/2008 7:31:00 AM •
Toshiba...
Answered
on Dec 05, 2008
Convergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
11/17/2008 7:50:05 AM •
Toshiba...
Answered
on Nov 17, 2008
Toshiba TP50F50 rear projection tv power light blinks on&
did you purchase these because you thought this was part of the problem? if is a convergance problem you should have some picture it would be distorted or color bars would be on the left or right of the screen. if the light is flashing and you have no picture at all or any audio you have a power supply problem. it is not letting the proper voltage energize the main board.
9/2/2008 5:10:29 AM •
Toshiba...
Answered
on Sep 02, 2008
Update firmware tv toshiba regza 52rv530u
You will need a computer and flash drive for firmware if your set isn't smart, go to manufactues website, put in model number and follow instructions, it's fairly easy to do
6/26/2022 10:41:55 PM •
Toshiba...
Answered
3 days ago
Toshiba DVR620 dubbing from VCR to DVD
Have you recently updated the firmare on your DVR device ? If so, it could be that Toshiba removed the feature that allows you to copy movie DVDs to attempt to protect the intellectual property of the movie studios. Either that or your DVD provider has removed the feature/capability to engage in that type of DVD copying. Please look into this. Thank you.
6/14/2022 6:04:22 PM •
Toshiba...
Answered
on Jun 14, 2022
