20 Most Recent Toshiba TZ61V61 61" Rear Projection Television Questions & Answers
This is probably NOT a chip. Put the model number in a search engine with the words "power supply"
Toshiba TZ61V61... | Answered on Oct 21, 2013
Power supply problem.Maybe deffective regulator transistor.Need for repair and troubleshoot and replace deffective parts.
Toshiba TZ61V61... | Answered on Jul 09, 2011
The blinking red light is telling you the code. Watch how many times it blinks. when it pauses for a seccond, watch again. Write down the number of times between each pause. Then repost with that info and I might be able to figure out what is wrong. Hopefully before it is permanent.
Toshiba TZ61V61... | Answered on Jun 12, 2011
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Toshiba TZ61V61... | Answered on Feb 25, 2011
The vertical deflection has stopped which cuts off the picture tubes to prevent burn in. Check the vertical output or the deflection board may need replacement.
Toshiba TZ61V61... | Answered on Aug 09, 2010
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Toshiba TZ61V61... | Answered on Aug 05, 2010
It is the convergence chips in the tv. They can be replaced at a repair shop or by any one with experience in soldering. You can find them online
Toshiba TZ61V61... | Answered on Jun 28, 2010
Hi.
If you get audio, and TV menu, but you have no raster, then the fault is concerning either the video input/video processing on main digital board, or the optical group.
Lamp and ballast are working since you can see TV menus and closed captions.
Test the TV using different inputs and input cable (you may have gone through this already). Try at least two different inputs (eg AV cable, SCART, component , HDMI...)
Ensure you use Source/Input button to browse channels.
That can at least tell you if the problem is the video input, or the video processing.
Either than that you will need a technician testing the TV at component level to find the fault.
If you want to contact an authorized technician, or if you want to get a quote on repair, you can call the number listed on the owners manual.
Regards.
Toshiba TZ61V61... | Answered on Dec 09, 2009
go into menu and adjust convergence. if red moves, it just needs adjusting from your remote. if it doesnt move or is bent then you have a bad convergence ic. possible fuse. suggest local service center. sorry
Toshiba TZ61V61... | Answered on Nov 10, 2009
Have you tried a different input? Also have you tried a different source for example if your using your cable try a dvd player of video game system. This way you can isolate exactly what the problem is. also make sure that the video is hooked up to the corresponding audio. Once I have more information I can assist you further.
Thank you,
lee
I have a few questions and A VERY GOOD IDEA OF WHAT IS WRONG WITH YOUR SET.
Go into the customer menu and select Convergence: if the blue is skewed OR WILL NOT MOVE IN SOME DIRECTION, the set has a bad convergence IC.
Based on WHAT YOUR MODEL NUMBER IS this set uses TWO of the STK-392-110 CONVERGENCE IC's.
If you have some skills at soldering and are handy I can give you general instructions and also tell you what you will need
2 new STK-392-110 CHIPS
1 good soldering iron
Solder
de-soldering braid or wick(to remove solder)
Some liquid solder flux (used to un-solder and then when re-solder new parts in.
Some heat sink2.gif compound(applied to the back of the new chips before installed)
THE ABILITY TO GET AT THE CHIPS---I can if you want tell you what is involved here--this is really the hard part on most of these sets--yes, each chip does have 18 pins that have to be unsoldered/ soldered in.
Let me know if you are able to do it or if you HAVE ANY QUESTIONS OR NEED ADVICE--I am here to help..
Regards, SD TECH
Toshiba TZ61V61... | Answered on Oct 27, 2009
un dia me cai patinando y me rompi la codera y me corterto otra patinadora sobre hiello
me operaron la cdera y cosieron los dedos
Toshiba TZ61V61... | Answered on Feb 26, 2009
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Toshiba TZ61V61... | Answered on Apr 13, 2008
Try this. It might work or it might not
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Toshiba... | Answered 4 hours ago
You will have to disassemble the unit to get access to and remove the stuck tape. Keep track of the disassembly process for reassembly with no parts left over.
Toshiba... | Answered on Jul 04, 2020
Use code search on the URC to find something that works. If a search through all codes stored in your One for All fails, try a different URC. All URCs do not contain all possible codes.
The trouble with the video cassette recorder is it is full of rubber components - belts and wheels that don't age well, though it is doubtful that is the only problem.
Capacitors too, often don't age well, especially if the unit could have been subjected to high summer temperatures or freezing winter temperatures but again that probably wouldn't render the machine completely unresponsive.
It should be possible to remove the top cover of a front loader and turn the mechanism by hand to remove the tape but putting it back into working order should be left to a professional. There is often an internal fuse and it could be worth checking that...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Toshiba... | Answered on Jul 01, 2020
Toshiba TZ61V61 61" Rear Projection Television Logo
Popular Tags
16 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
tz61v61 red blues out line
  • Televison & Video
