20 Most Recent Toshiba 43AX60 43" Rear Projection Television Questions & Answers
you need to explore menue for tv options and select the proper input as well as other options.
Toshiba 43AX60... | Answered on Sep 17, 2012
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Toshiba 43AX60... | Answered on Sep 14, 2007
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Toshiba 43AX60... | Answered on Jul 04, 2007
CHECK WITH TOSHIBA WEBSITE
Toshiba... | Answered on Jan 14, 2020
Very good, I think I found the knowledge I needed. I will see and refer some information in your post. thank you build royale
I also find out about this, hoping to find the best answer slope game
When it does not power up, just start checking the fuse. When you have a multimeter, you can check if the power still comes in the tv. Also go on to check if the on / of switch does work correct. But if you don't have electronic skills at all, please ask a technician, because inside the tv you can find lots of places where the high voltages can harm or even can kill you.
Toshiba... | Answered on Jan 12, 2020
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Toshiba... | Answered on Jan 11, 2020
Make sure the display resolution is set correct for your TV,
How to change the display resolution for your TV on your Xbox One...
Also make sure the TV is on and set to the correct HDMI input before using the Blu Ray.
It is also possible the TV does not support HDCP, if not, it will not work with the XBOX one Blu Ray. You may be able to use the Component (Red Green and Blue) cable though.
Toshiba... | Answered on Jan 08, 2020
go into picture set up and turn on back light
Toshiba... | Answered on Jan 06, 2020
Original DVD discs like Hollywood movies don't work,usually dirty,greasy,smushes,scratches or cracks on thems.So the DVD player laser eye can't read the datas on them.Coppies DVD Discs depending on the fanalizing codes that was burn on the DVD disc itself,those maker of the DVD players that share their codes widely in the industries.Those DVD players,play the most of the majorities of the DVD coppies burn in DVD Discs.
Toshiba... | Answered on Dec 30, 2019
Toshiba 43AX60 43" Rear Projection Television Logo
Popular Tags
8 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
no picture menu screens or anything
  • Televison & Video
