20 Most Recent Toshiba 50A60 50" Rear Projection Television Questions & Answers
How do I change the bulb?
http://www.manualslib.com/t/toshiba+50a60.html
6/5/2016 5:21:37 AM • Toshiba 50A60... • Answered on Jun 05, 2016
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
5/29/2016 6:23:02 PM • Toshiba 50A60... • Answered on May 29, 2016
I have a 50A60 toshiba 50 in rear projection tv I have a green screen no pic but I have sound
Is there a cable or Satellite box hooked up for signal?How and where is signal connected to the TV?
12/14/2012 6:21:21 AM • Toshiba 50A60... • Answered on Dec 14, 2012
I have a Toshiba Theaterview
There is no apreciable radiation from these tubed projectors unless the EHT supply exceed 33KV which is highly unlikely.
Replacing the screen could be quite costly though. Look up a Toshiba Repair agent for a price and maybe ebay as well.
Hope that helps.
1/2/2011 5:27:48 PM • Toshiba 50A60... • Answered on Jan 02, 2011
Someone donated a toshibia 50A60 rear projection
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must be requiring to change 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board,to solved the tv convergence picture problems.Find some one in ur church can do basic electronic soldering,have all the tools?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit,also included a DVD disc for tutoring u how to do it that belong to ur tv make and model to repair it,the convergence problems by ur self.Or the shop,will cost u like $300-350 for parts and labors.
12/8/2010 5:15:15 PM • Toshiba 50A60... • Answered on Dec 08, 2010
I have Toshiba Theaterview 50A60
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
10/9/2010 8:53:42 PM • Toshiba 50A60... • Answered on Oct 09, 2010
Can the screen on a Toshiba Theaterview be ordered
Lokk at encompassparts dot com. Enter model #.
4/20/2010 1:10:12 AM • Toshiba 50A60... • Answered on Apr 20, 2010
Good morning, I need to clean inside of my Toshiba
Yes I Had The Same problem , if your handy with fixing things this will
work.
Step 1- unplug the TV from wall socket
Step 2- disconnect all devices like VCR's DVD Players from the TV
Step 3- remove the speaker covers from the TV
Step 4 - There are 14 screws on front cover, remove these with a
Philips driver, set cover aside
clean with soft brush and wash with water
Step 5- Gently raise the cover straight up to release it from its supports
Once cleared from supports , remove the cover.
Tips- Make sure you don't scratch any of the screens or CRTs
You can clean the mirror with any glass cleaner, make sure to wipe it
clean , water and vinegar does a good job to eliminate streaks.
Use a soft duster to clean the dust from the circut boards
Tip - Remember take it easy when cleaning
When your finished cleaning, just reverse the steps
It Worked for Me
2/17/2010 7:53:24 AM • Toshiba 50A60... • Answered on Feb 17, 2010
Screen was pushed in. Black screen broken. Can TV
yes it would be worth the trouble and expenses. Get it repaired.
11/7/2009 4:12:41 AM • Toshiba 50A60... • Answered on Nov 07, 2009
2answers
Toshiba 50A60
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
9/30/2009 2:15:51 PM • Toshiba 50A60... • Answered on Sep 30, 2009
Blinking red Light
Hi, thank you for visit fix ya.
Common problems on this tv ( cause no power):
1.- Loose connection between connectors and cool solder around fly back. ( re solder all).
2.- IC vertical output and capacitor in same section ( 100uf, 220uf,3300 uf and 2.2uf ), replace all.
3.- STKs ICs convergence , need be replace ( check any resistor around STKs, for burn or brown color).
----- Try to do step by step; you will repair your tv.
I will be here for any future question.
Thank you
7/26/2009 4:23:51 PM • Toshiba 50A60... • Answered on Jul 26, 2009
Picture seems darker or less intense light
You will need to post tv brand and model number
3/26/2009 1:54:45 PM • Toshiba 50A60... • Answered on Mar 26, 2009
No picture no sound
You will need to trouble shoot the various power supplies most likely something minor in either the stand by or start up circuits. I recommend that you get a service manual at the following link as they will email it to you and also help you diagnose it with free tech support. Here is the link.
http://servicemanuals.vstore.ca/
10/13/2008 11:39:43 PM • Toshiba 50A60... • Answered on Oct 13, 2008
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
9/12/2008 6:33:26 PM • Toshiba 50A60... • Answered on Sep 12, 2008
4answers
TOSHIBA 50A60,GOING TO REPLACE LENTICULAR SCREEN
It's pretty simple repair.  Pull bezel, unscrew braces around edges and swap screen out.  Where did you find the lenticular at?  I have the same TV and can't find the part online.
Thanks
5/29/2008 3:32:38 AM • Toshiba 50A60... • Answered on May 29, 2008
2answers
Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
4/14/2008 2:39:29 AM • Toshiba 50A60... • Answered on Apr 14, 2008
PIP
this tv does not have 2 tuners. So you will be unable to get 2 different channels on one screen. I have the same tv. The PIP is only good for watching a dvd/video and tv swapping only.
4/9/2008 9:35:26 PM • Toshiba 50A60... • Answered on Apr 09, 2008
Toshiba 50
Your convergence ICs need to be replaced. Its an easy and cheap repair if you can solder. Parts will cost about 20.00 for both ICs
3/27/2008 1:03:19 AM • Toshiba 50A60... • Answered on Mar 27, 2008
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
1/7/2008 2:42:28 AM • Toshiba 50A60... • Answered on Jan 07, 2008
Toshiba 50A60 50" Rear Projection Television Logo
Popular Tags
34 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
good morning need clean inside toshiba
  • Televison & Video
