20 Most Recent
Kocaso MID M9100 9 Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Multi-Touch 8GB 512RAM Tablet PC-Purple Questions & Answers
I'm locked out my tablet and it won't let me get on
Try performing a power reset. There should a power reset button near the charging port.
It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button
inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours
before using it. If you leave it on the charger for longer than the allocated time, you will go
back to having the same problem as before.
Support Troubleshooting Guide
I cannot access internet it says I have drivers missing I have a KOCASO M9100 android 4.2
The drivers are built into the firmware, so this is unusual.
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Can not move past Android screen HELP
Kocaso m9100 tablet drivers
There are no drivers, they only come with the firmware, so you would have to update the firmware to install them.
MY PAD WILL NOT STAY ON AFTER RESET AND POWER ON
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
M9100 boot ans stuck on android screen
Debugging mode has to be engaged by running ADB, but becomes quite complex and device specific. Plus it can stop your tablet from working all together, so try this first.
Why won't my android tablet turn on?
I had this same tablet...it quit on me after 2 months. I called the company and they replaced it with a M9200 which would not turn on after 1 month. I found the factory reset button on the back under a small sticker. Plug it into the charger and gently push a sharp toothpick or other sharp non metallic object inthe the small hole until you get resistance. Then gently push 'till you feel a tiny click...this should reset the tablet. Mine crapped out because it is a junk company. There are more complaints on this company than any other I have ever seen. I wised up and bought Google Nexus 7...best 7" tablet made.
My kocaso m9100 tablet is locked and my niece doesn't remember the password how do I reset it so I can use it
Google play store has stopped
Dear Paul,
Nothing to be worried. Just do one thing connect ur mobile or device with internet and first login with a existing google mail id and then open your play store. ok i hope it will work.
