Heres a text i found that should be usefull...
Originally Posted by
WaltA
Do
you have any instructions on how you got each piece off? I mean, where
the clips or screws were located, and which held on which piece?
Walt, good to hear from you again. You helped me out quite a bit
getting familiar with this set when i first purchased it. If i remember
correctly you have the 46HX83.
Should be the same deal then. Speaker panel just pulls off. I started
at one side on top and get that clip loose 1st, then the bottom one on
the same side, then the other side top and bottom and then the middle.
This exposes the silver fascia behind the speaker grill. I believe
there were 8 screws total holding this on, 2 above and below each
speaker. These are torx(sp?) head screws, i don't know what # they are,
but fairly small. All screws by the way, that go into wood on this set
are the same size torx screw. All other screws that go into plastic are
the same size screw only with a 1/4" hex head and phillips. After the
bottom silver fascia is removed you can get to the screws holding the
panels between the screen and the speaker section. The panel that has
the drop down door with controls and the power button has 2 or 3 screws
holding it in. They are all along the bottom of the panel. It has wires
running into it obviously and not alot of slack. However, it doesn't
weigh very much so i just rested it against the set. I did not
disconnect these wires as you can see in the pics. The other panel is
just for looks. Same deal here, 3 screws at the bottom(there are alot
more mounting holes on all parts mentioned so far but not all of them
had screws in them, so yours may have more or less screws to remove).
NOW THIS IS IMPORTANT, there is a small piece of MDF type board right
behind these 2 panels, it's about 1" tall and the same thickness by
about 18" or so long. When removing the screws holding in these 2
panels that board is very loose (it actually comes out, and i took it
out until i was done)and could fall out on its own, so i would remove
it and set it aside. Now all that's left is removing the screws holding
the screen in place. All the silver fascia around the screen and what's
available to see from the front below the screen is all one piece. I
removed the ones in front 1st, then the sides from behind the screen
then the top ones from behind the screen. THIS IS IMPORTANT AS WELL.
There is a wiring harness attached to the screen from the set. My
harness is visible in the pics. The wires are red and the
harness(plastic) is white. This needs to be disconnected to be able to
get the screen off the set to store while you are working on your set.
I was able to disconnect mine before removing the screen however there
was a type of wire loom or holder that had to be opened to get the
loose end out of the way. Would be a good idea to have another set of
hands around for this part(i used my wife, yes, it was that simple).
We each grabbed an end of the screen and carried it over to a spot on
the floor where i had laid a clean sheet down.Well, that's it for the
screen removal, goes back together in the reverse order i just
explained of course. And keep in mind that this is a do at your own
risk project. I can't be held responsible for anyone's set but my
own,but in saying that, it really wasnt that hard to do.
I did not restack my screens or remove the glare screen as i have total
light control in this room. I only wiped the back of the screen off
with a microfiber cloth, same type i use on the shiny front side. I'll
post more about the focusing and cleaning either today or tomorrow,
i've got a few things to get done here, hope this helps you guys out .
edit: In looking at my pictures again,you can see that MDF mentioned
right below the 2 cpanels between the screen and speaker section. It
actually comes loose when you remove the screws on the silver fascia at
bottom of screen. Sorry about that.
and here's the link to the page it came from, with pics of the cleaning of the lenses and such:
_______http://
www.avsforum.com/avs-vb/showthread.php?t=425650&page=60___________
