20 Most Recent PfaFF Sewing Machine Metal Bobbins Questions & Answers
Pfaff 1469 needs a hand tug to get running every time after pressing foot pedal. How to service it?
If your Pfaff 1469 sewing machine needs a hand tug to get it running every time after pressing the foot pedal, it could be due to several reasons. Here are some steps you can take to service the machine:
  1. Clean the machine: Dirt, lint, and debris can accumulate in the machine, causing it to jam or run slowly. Use a brush or vacuum cleaner to remove any debris from the machine.
  2. Oil the machine: Lack of lubrication can cause the machine to run slowly or seize up. Use a good quality sewing machine oil to lubricate the machine according to the manufacturer's instructions.
  3. Check the foot pedal: The issue could be with the foot pedal. Check for any loose or damaged wires, and ensure that the pedal is properly connected to the machine.
  4. Adjust the tension: If the machine is not properly threaded or the tension is too tight, it can cause the machine to jam or run slowly. Check the threading and adjust the tension as needed.
  5. Check the belt: If the belt is loose or damaged, it can cause the machine to run slowly or not at all. Check the belt and replace it if necessary.
  6. Check the motor: If none of the above steps resolve the issue, it could be a problem with the motor. Check the motor and wiring for any damage, and consider having it serviced by a professional if needed.
It is important to follow the manufacturer's instructions when servicing your Pfaff 1469 sewing machine. If you are not comfortable servicing the machine yourself, consider taking it to a professional for repair.
3/14/2023 5:53:18 AM • PfaFF Sewing... • Answered on Mar 14, 2023
PFAFF creative 1471-sewing foot?
It's not the foot, it is the 'Feed Dogs', the teeth in the base that pull the material UNDER the foot. The most likely reason is that you have lowered them too much, or set it to 'embroidery'. Page 50 https://www.manualslib.com/manual/969570/Pfaff-Creative-1471.html?page=50&term=Dropping+The+Feed+Dog&selected=1#manual ManualsLib https://www.manualslib.com > ... > Creative 1471 View and Download Pfaff Creative 1471 instruction book online. Creative 1471 sewing machine pdf manual download.
Pfaff creative 1471 user manual (English - 76 pages)
Manuals.ca https://www.manuals.ca > Sewing machines > Pfaff User manual. View the manual for the Pfaff creative 1471 here, for free. This manual comes under the category Sewing machines and has been rated by 5 people ... ..
3/9/2023 6:16:08 AM • PfaFF Sewing... • Answered on Mar 09, 2023
Pfaff 145 Sewing Machine not stitching. I have a phaff 1245 and I never even heard of this machine. I may have popped the clutch but I cant find it?
Question edited for clarity and the correct spelling of 'maker name model (what it is)' as the first three words. Pfaff are very well known Phaff aren't :>D https://www.google.com/search?q=pfaff+1245 Add the word 'Parts' to that search query and press enter. More on this one than your Nakamichi. You need to go to Japan for that one. I suspect all the manuals are in Japanese. ..
3/8/2023 6:38:00 AM • PfaFF Sewing... • Answered on Mar 08, 2023
2answers
Where are the oil holes
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
2/27/2023 8:20:40 PM • PfaFF Sewing... • Answered on Feb 27, 2023
3answers
Display does not light up on PFAFF 1475 CD
These instructions apply to PFAFF 1475 CD. They may also work for other machines. If you have some advanced electronic repair skills and tools, check the following: For 220 Volts models - there is a fuse next to the power input, make sure it is good. There is no such a fuse for 120 Volts model. If the fuse is Okay, you have to get access to the main circuit board by removing the bottom cover. Check the primary on the transformer for 120 V AC (220 V AC respectively). Check the secondary side for 5 V AC (luminescent display), 9 V AC (turns to 5 V DC by rectifier, 4700 micro farads capacitor and a 5 V regulator STI L387A) and 28 V AC (turns to 35 V DC by rectifier and 2200 micro farads capacitor. Pay attention to two soldered round fuses in series with the secondary 9 V and 28 V - both should be good. On the big capacitors you should have 9 V DC and 35 V DC. Common symptoms for bad small 22 micro farads capacitors next to the some of the IC's - there are 5 of these: These capacitors are in parallel with 5 V DC. ## All of the LEDs light up but the display is blank ## All of the LEDs light up, the display is blank, and after a minute no LEDs at all ## No LEDs nor display. Replace ALL five 22 micro farads capacitors using a good desoldering pump or desoldering station!. Enjoy your resurrected PFAFF 1475 CD machine!!! I just did this procedure on my aunt's one (Made in West Germany around 1990).
2/27/2023 6:11:39 AM • PfaFF Sewing... • Answered on Feb 27, 2023
Where can I find a stepper motor for a Pfaff 1475cd sewing machine? They don't make them any more.
If the original stepper motor for your Pfaff 1475cd sewing machine is no longer available, there are a few options you can consider:
  1. Check with sewing machine repair shops in your area. They may have access to refurbished or used stepper motors that can be used as a replacement.
  2. Look for replacement parts online. Some websites specialize in selling replacement parts for sewing machines, including stepper motors. You may be able to find a compatible replacement part online.
  3. Consider retrofitting your machine with a new motor. This may require some modification to the machine and electrical components, but it could be a viable option if you're unable to find a direct replacement.
  4. Contact Pfaff or the manufacturer of the original motor to see if they have any suggestions or alternative options.
It's important to note that not all stepper motors are compatible with all sewing machines, so it's important to do your research and find a replacement part that is specifically designed to work with your Pfaff 1475cd.
2/24/2023 2:40:32 PM • PfaFF Sewing... • Answered on Feb 24, 2023
On my Pfaff quilt expression 4.2 the knee lift is not working
It sounds like you're experiencing an issue with the knee lift on your Pfaff Quilt Expression 4.2 sewing machine. Here are a few steps you can try to resolve the issue:
  1. Check the knee lift lever: Make sure that the knee lift lever is not obstructed and that it is properly positioned.
  2. Check the linkage: The knee lift mechanism is connected to the sewing machine via a series of linkages. Make sure that all linkages are connected and not broken or bent.
  3. Lubricate the knee lift mechanism: If the knee lift mechanism is stiff or difficult to move, try lubricating it with a sewing machine oil.
  4. Check for loose screws: Check for any loose screws or bolts that may be causing the knee lift mechanism to malfunction.
  5. Check the foot control: Make sure that the foot control is functioning properly and that it is securely connected to the sewing machine.
If none of these steps resolve the issue, it may be necessary to take your sewing machine to a professional for repair.
2/23/2023 3:07:24 PM • PfaFF Sewing... • Answered on Feb 23, 2023
How do you access the top of a Pfaff 1020 sewing machine?
To access the top of a Pfaff 1020 sewing machine, you will need to remove the top cover by unscrewing the screws located on the back of the machine. Once the screws are removed, the top cover can be lifted off to access the internal components.
1/30/2023 4:53:25 AM • PfaFF Sewing... • Answered on Jan 30, 2023
Display shows battery on my pfaff anniversary edition
For a 7550, this has been noted, AND also, if batteries show leak or any corrosion, clean only with mild soap, dish, do not use acetone, alcohol, any aggressive such as these can damage plated contacts.
How do I change the battery in my PFAFF 7550 creative sewing machine?
Switch on the sewing mahine to avoid deleting the memories during the battery change. Tilt the machine over backwards. A battery compartment is installed i the base. Using a screwdriver (as a lever, not to unscrew anything), pry up/off the cover. Take out the batteries. Insert new batteries with the "+" side facing upward. Replace the cover -- hinges should engage in the lower recess; the cover should snap in place. Use heavy duty batteries, such as Duracell. Battery size is AA
1/17/2023 8:18:14 PM • PfaFF Sewing... • Answered on Jan 17, 2023
Pfaff 7550 creative only sewing in zig zag stitch.
It sounds like your Pfaff 7550 Creative may be experiencing a hardware-related issue. To diagnose the problem, try resetting the machine by unplugging the power cord and waiting 10 minutes before plugging it back in. If the problem persists, then it is likely that the machine's control circuit board may have become damaged and will need to be replaced. Additionally, you should also check that the machine is receiving power by testing the power cord, power switch, and the foot pedal. If all of these components are working correctly, then the control circuit board will need to be replaced. If you need further assistance, you can consult a professional Pfaff technician for diagnosis and repair.
1/6/2023 11:27:08 AM • PfaFF Sewing... • Answered on Jan 06, 2023
Lowering the presser bar on a Pfaff 1473
1/5/2023 5:43:22 AM • PfaFF Sewing... • Answered on Jan 05, 2023
Why won't the release disk disengage needle for bobbin winding?
is there an oil hole on the hand wheel near the hub? if so then put a couple drops of sewing machine oil in there and it should go back to working .
12/18/2022 5:21:49 PM • PfaFF Sewing... • Answered on Dec 18, 2022
3answers
Where do I find replacement screws for a Pfaff 130
A local sewing machine center will have your screw if not exactly they will have a similar size and pitch of the screw threads. 99% they will have something similar even though it's not the same brand.
12/13/2022 2:02:45 AM • PfaFF Sewing... • Answered on Dec 13, 2022
2answers
Light Switch, Pfaff #70-112000-02 Do you have one in stock and how soon can I receive it.
We are FIXYA dot com. We don't sell anything. We only supply free information. There are sellers in the link. The cost is $18. Delivery is likely 3 to 7 days. https://www.google.com/search?q=Light+Switch%2C+Pfaff+%2370-112000-02
10/20/2022 5:04:41 PM • PfaFF Sewing... • Answered on Oct 20, 2022
2answers
Where can I get a CD for my pfaff creative 7550 sewing [email protected]
I would try pfaff.com firstly.
10/19/2022 7:42:38 AM • PfaFF Sewing... • Answered on Oct 19, 2022
PfaFF Sewing Machine Metal Bobbins Logo
1 questions posted
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • PfaFF Sewing Machines
Most Popular Question
pfaff 1469 needs hand tug get running
  • Sewing Machines
