20 Most Recent
Cfm MCP44 Window Air Conditioner Questions & Answers
35,000 cfm = ?pounds trust
There is no equivilancy between the two...pounds of thrust would be 'foot pounds of torque' and cfm is the amount of air delivery is passing a specific sized opening in cubic feet per minute.
If you are looking at how much pressure is in for instance a residential air conditioning system, they are typically designed for .5"w.c. total system static. Meaning the pressure in the supply air duct plus the negative static added together cannot exceed .5" of water column. Approximately 28" w.c. per pound of pressure and we don't want any more than 1/2 of one inch water columm....
Now if you're talking about turbo-chargers....thats a different story and I haven't a clue.
F1 flashing on split system
You need to determine what that code means by reading on your blower doors back side, there will be a set of codes pertaining to your make, model whatever that is as you did not furnish it.
