20 Most Recent Toshiba 27A30 27" TV Questions & Answers
0answers
How do I turn stereo sound off?
Refer its user manual for details. Gopakumar Gopalan Google
8/7/2014 4:49:22 AM • Toshiba 27A30... • Answered on Aug 07, 2014
manual
Flat screen toshiba tv black screenbut a sound
hello, usually in that case, the cause to the failure, is the inverter board. but first you have to chek the 24v that should be supplied to the inverter. if the voltage is ok. then you should replace the inverter board
5/20/2011 12:36:20 PM • Toshiba 27A30... • Answered on May 20, 2011
Can you reset toshiba tv
Hello
If you forget the passcode "press recall four times within 5 seconds from the V-Chip menu.This allow you to proceed to the blocking menu and resets your PIN code. OK.
4/27/2011 5:55:24 AM • Toshiba 27A30... • Answered on Apr 27, 2011
WHERE CAN I PURCHASE A
I found it at:
Encompass & HBF Electronics . This part is quickly falling off the radar and many places list it as NLA (no longer available), meaning they are no longer being produced. When they're gone - they're gone. Buy one if you want it while you can.
I hope this helps and good luck. Please rate my reply. Thank you.
4/13/2011 8:56:27 PM • Toshiba 27A30... • Answered on Apr 13, 2011
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
10/11/2009 3:10:11 PM • Toshiba 27A30... • Answered on Oct 11, 2009
My universal remote stopped working, I bought
It was the TV set! I googled remote control problems and went on one of the websites......The answer was quite simple, unplug the TV for a few minutes and let it reset itself. I did and it did! I guess it's no different than a cell phone or computer sometimes!
9/17/2009 5:38:57 PM • Toshiba 27A30... • Answered on Sep 17, 2009
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
7/5/2008 11:51:11 PM • Toshiba 27A30... • Answered on Jul 05, 2008
Toshiba TV
Try unplugging the set for about 2 minutes to reset the TV. The other possibility is a stuck button on the TV or a remote control near the set that is randomly sending out signals.
3/26/2007 6:38:12 PM • Toshiba 27A30... • Answered on Mar 26, 2007
2answers
Toshiba 27A30 that blows Fuse
Jeff, If your not a technician please dont mess with the set as you can get seriuoly hurt by experimenting. And replacing a fuse that is black is only going to blow again and possibly cause more problems and damage the set more then it already is. Your problem is a shorted B+ rectifier or a capacitor or voltage regulator IC. If you don,t know what this is, or you don't know how to solder, as well as unsolder, Please seek out a pro to assit you with this repair. Good Luck
8/7/2006 1:45:47 AM • Toshiba 27A30... • Answered on Aug 07, 2006
2answers
How come my 10-year-old toshiba tv now goes to screensaver in the middle of a program I'm watching
Hi, Please factory reset your toshiba tv or update your tv settings so that the screensaver is disabled. Either of these 2 actions should help you overcome this issue. If you don't see a screensaver option on your remote, please reference the table of contents within your manual. Thank you.
11/5/2022 4:23:48 AM • Toshiba... • Answered on Nov 05, 2022
2answers
Toshiba 49L420U does not turn on
The 5 and 3.3 voltage is standby and that would be good if you get a standby light, you won't see the 16 volt unless the power supply is at full power or out of sleep mode. Look at the legend on the power board connector going to the main for something like PWR_ON, it may be marked different, but will have something about power on, you need to see just over 3 volts there when you push the power button, if 3 volts is there replace the power supply, if you don't see that go to the connector coming from the inferred board on the main board, measure the voltage at the pins, one will be 5 volts and one of the others need to change voltage when you push the power button on the remote, measure these one at a time, if none chance replace that board, if you see a change in voltage on one of the pins replace the main board.
9/14/2022 12:03:24 AM • Toshiba... • Answered on Sep 14, 2022
Toshiba 27A30 27" TV Logo
19 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
reset toshiba tv
  • Televison & Video
