20 Most Recent Samsung 6350 Series UN65F6350 65" LED Smart TV 1920x1080, 240 Hz, HDTV Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung 6350... | Answered on Mar 18, 2016
Hi William I have the same tv. It had the same problem. I had to have the main board replaced. It seemed to fix the problem of turning on and off randomly but now i have a problem with the screen.
Samsung 6350... | Answered on Mar 17, 2016
Problem of a part thats lead to or the driver itself from the LED backlight matrix board thats behind the lcd screen. begin with measure from the powersupply and the beginning testpoints and fuse resistors . of the matrix board ,
look for a Service manual or let it repair in your Country
Samsung 6350... | Answered on Dec 29, 2015
According to the Samsung support website there is an option in the menu which is called "caption" which can be selected off or on.
This is a link to a copy of the manual.
Samsung UN65F6300AF manual
In the manual it says to select the onscreen menu and then ...
Subtitles
Screen Menu > Broadcasting > Caption Try Now
View subtitles along with subtitle-enabled digital and analog broadcasts.
Show Subtitles
Screen Menu > Broadcasting > Caption > Caption Try Now
Show subtitles. Subtitles will be displayed when you choose a broadcast that supports subtitles.
"" DVD Subtitles are only available when connected to an external input connector.
Samsung 6350... | Answered on Mar 13, 2015
Using the TV remote. Enter the setup menu for the TV. Choose Acessibility Options.
Samsung 6350... | Answered on Feb 22, 2015
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Samsung 6350... | Answered on Aug 12, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Samsung LE... | Answered on Mar 11, 2015
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
Samsung LE... | Answered on Mar 04, 2015
Most likely the power supply capacitors. you can identify them by their bulging tops.
Samsung LE... | Answered on Jul 24, 2014
Samsung 6350 Series UN65F6350 65" LED Smart TV 1920x1080, 240 Hz, HDTV Logo
6 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
dark shadow bottom half screen still
  • Televison & Video
