20 Most Recent
Toshiba CX36F85 36" TV Questions & Answers
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
My Toshiba DLP Projection TV model number 44NHM84 will turn on but shuts off after 1-2 minutes. What do I need to do to fix this issue?
There are several reasons why your Toshiba DLP projection TV might be turning off after a few minutes. Here are some steps you can take to try and diagnose and fix the issue:
- Check the lamp: The most common reason for a DLP TV to shut off after a few minutes is a faulty lamp. Check the lamp to see if it's still functioning properly. If it appears to be damaged or has reached the end of its life (typically around 2000-3000 hours), replace it with a new one.
- Check for overheating: Overheating can also cause the TV to shut off. Check the fan to see if it's running properly and clean any dust or debris that may be blocking the airflow.
- Check for firmware updates: If the TV's firmware is outdated, it can cause it to shut off. Check the manufacturer's website for any available firmware updates and install them if necessary.
- Check the power supply: A faulty power supply can also cause the TV to shut off. Check the power supply unit to see if it's functioning properly and replace it if necessary.
- Check the color wheel: If the color wheel is damaged or not functioning properly, it can cause the TV to shut off. Check the color wheel for any damage or signs of wear and replace it if necessary.
If none of these steps solve the issue, it may be necessary to have a professional technician diagnose and repair the TV.
3/18/2023 8:32:27 AM •
Toshiba...
Answered
on Mar 18, 2023
I need a code for a Toshiba tv and I have a yk524-01 remote
Here are the steps to program your YK524-01 remote to your Toshiba TV using a code:
- Turn on your Toshiba TV.
- Press and hold the "TV" button on your YK524-01 remote until the LED light blinks twice.
- Enter one of the following 3-digit codes for Toshiba TVs: 115, 125, 136, 156, 159, 160, 170, 179, 185, 195, 204, 216, 218, 227, 228, 229, 231, 233, 235, 236, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255.
- Press the "Power" button on your YK524-01 remote. If your Toshiba TV turns off, the code has been successfully programmed. If your Toshiba TV does not turn off, repeat steps 2 to 4 with a different code from the list.
If none of the codes work, you can try the automatic code search method:
- Press and release the "Power" button on your YK524-01 remote.
- Press the "CH+" button repeatedly until your Toshiba TV turns off.
- Press and release the "TV" button on your YK524-01 remote to save the code.
I hope this helps!
3/8/2023 11:49:10 AM •
Toshiba...
Answered
on Mar 08, 2023
Toshiba mod#65l621u.flashing red light 5times
The flashing red light on your Toshiba TV indicates a malfunction or issue with the device. The 5 blinks specifically indicate a problem with the power supply, which could have been caused by the hand control being dropped.
Here are a few steps you can try to fix the problem:
- Unplug the TV from the power source and wait for a few minutes before plugging it back in.
- Check the power cord for any visible damage, such as frayed wires or loose connections. If the cord is damaged, replace it with a new one.
- Ensure that the electrical outlet the TV is plugged into is functioning properly and has a strong connection.
- Try connecting the TV to a different power source or electrical outlet.
- If the issue persists, it is possible that the TV's power supply unit has been damaged and may need to be replaced. In this case, it's best to contact a professional for repair.
Please note that attempting to repair the TV yourself can be dangerous and may cause further damage, so it is recommended to seek professional assistance if you are not comfortable with electronics repairs.
3/4/2023 9:54:45 AM •
Toshiba...
Answered
on Mar 04, 2023
Toshiba air conditioning unit not working RAS-13UKH-G
If the operation light is blinking, it means there is an error with the unit. The number of blinks can indicate what the error is.
Here are some common error codes for Toshiba air conditioning units:
- Blinking once: Indoor unit room temperature sensor error
- Blinking twice: Indoor unit coil outlet temperature sensor error
- Blinking three times: Indoor unit coil inlet temperature sensor error
- Blinking four times: Outdoor unit discharge temperature sensor error
- Blinking five times: Outdoor unit suction temperature sensor error
- Blinking six times: Indoor unit EEPROM error
- Blinking seven times: Outdoor unit EEPROM error
- Blinking eight times: Indoor unit remote control error
If you can determine the number of blinks, you can refer to the user manual to see what the error code means and what steps you can take to fix it. If you don't have the manual, you may be able to find it online or contact Toshiba customer support for assistance.
2/26/2023 7:18:15 AM •
Toshiba...
Answered
on Feb 26, 2023
Toshiba TV remote P/N IT860000011 select button does not work.
In the event that the select button on your Toshiba television controller isn't working, there are a couple of things you can attempt to investigate the issue:
Actually look at the batteries: Ensure the batteries in the controller are new and appropriately introduced. Frail batteries can cause some issues with the buttons not working as expected.
Clean the remote: soil and flotsam and jetsam can develop on the controller's surface and disrupt the button's functionality. Try cleaning the remote with a delicate, dry fabric.
Reset the remote: Eliminate the batteries from the controller and press every one of the buttons to release any lingering power. Then, reinstall the batteries and take a stab at utilizing the remote once more.
Supplant the remote: Assuming nothing from what was just mentioned advances work, it is conceivable that the controller might be flawed and should be supplanted. You can buy a replacement remote from a Toshiba seller or online retailer.
Assuming that the issue continues even after attempting these investigation steps, it is conceivable that there might be a more significant issue with the remote or the actual television, and looking for proficient assistance might be vital.
2/22/2023 6:59:32 PM •
Toshiba...
Answered
on Feb 22, 2023
How can you get to the menu on a Toshiba tv without a remote
If you do not have a remote for your Toshiba TV, there are a few ways you can access the menu to change settings or perform other functions:
- Use the buttons on the TV: Some Toshiba TVs have buttons on the side or back of the TV that can be used to access the menu or perform other functions. Check the TV's manual or the label on the back of the TV to see if this is the case for your TV and which buttons to use.
- Use a universal remote: You can purchase a universal remote that is compatible with your Toshiba TV. These remotes can be programmed to control your TV, and can be used to access the menu and other functions.
- Connect a keyboard or mouse to the TV: If your TV has a USB port, you can connect a keyboard or mouse to the TV and use it to navigate the menu and other functions.
- Use a mobile app: Some Toshiba TVs can be controlled using a mobile app that can be downloaded to your smartphone or tablet. This app allows you to control your TV and access the menu without needing a remote.
1/24/2023 7:48:36 AM •
Toshiba...
Answered
on Jan 24, 2023
Toshiba 50L2200U Won't Turn On
There could be an issue here with both the power supply and also an internal problem as well with your TV. The outlet that your TV is plugged into could be the issue here then.
1/24/2023 7:45:26 AM •
Toshiba...
Answered
on Jan 24, 2023
Toshiba lcd tv 22D1333B has no video/sound just flashing red/green power light?
it sounds like the issue may be with the AV MAIN board. The power board is providing the correct voltage to the board, but the board itself may be malfunctioning. It may be necessary to replace the AV MAIN board in order to resolve the issue with the TV not producing video or sound. It is also possible that the problem could be elsewhere, but the AV MAIN board would be a good place to start troubleshooting.
1/17/2023 4:48:56 AM •
Toshiba...
Answered
on Jan 17, 2023
Location of the ir sensor on Toshiba regza
The location of the IR sensor on a Toshiba Regza TV can vary depending on the specific model of the TV. However, in general, the IR sensor can be found in one of the following places:
- On the front of the TV: The IR sensor is often located on the front of the TV, usually near the bottom or the top of the TV.
- On the side of the TV: The IR sensor may be located on the left or right side of the TV.
- On the back of the TV: The IR sensor can also be located on the back of the TV, usually near the bottom or the top of the TV.
- On the remote control: The IR sensor can also be located on the remote control.
To locate the IR sensor, look for a small, clear or black plastic window that receives the signals from your remote control, it could be labeled with a name like "IR" or "remote".
It is recommended to consult the TV's user manual or contact Toshiba customer service for more specific information on the location of the IR sensor on your specific model of the Regza TV.
1/14/2023 12:12:28 AM •
Toshiba...
Answered
on Jan 14, 2023
Toshiba hdd/vcr/dvd recorder stuck on avi - won't change to tv using input on handset
please attempt to change the input from the Toshiba recording device directly. You might switch between modes on the Toshiba by pressing 1 of the hdd, vcr or dvd buttons. If this doesn't work, you can power cycle the device and then attempt to changed the mode from the Toshiba directly again. Otherwise, you might need to eject any disc that's currently in the device before attempting to change modes again.
Thank you.
1/4/2023 1:29:31 AM •
Toshiba...
Answered
on Jan 04, 2023
Humax RM-F01 instruction manual?
Humax Instructions
https://www.manualslib.com/manual/1472096/Systemline-S7-Netamp.html?page=5
Toshiba Codes
030, 204, 005, 115, 129, 092, 447,
364, 313, 304, 242, 212, 211, 183,
100, 039, 022, 020, 010, 009, 004,
236, 257
1/2/2023 9:12:22 PM •
Toshiba...
Answered
on Jan 02, 2023
