20 Most Recent Toshiba CF35F50 TV Questions & Answers
Hi
When the TV is turned off, try to bump on the two lateral sides with the two hand palms at the same time. If the set comes on, there are dried solder joints that need to be clean and ressoldered. Ressolder all the points where heavy componentes are placed: power switching transformer and switching transistor and flyback transformer and associated circuits and the small pcb attached to the CRT. I do not know why, Toshiba sets are prone to dried solder joinis.
Good luck.
Sully
Toshiba CF35F50... | Answered on Sep 27, 2013
Hello. Is the line is from left to right or top to bottom
Toshiba CF35F50... | Answered on Mar 02, 2011
Try a different input and see if you get a picture back...try tuner input. A blue screen shows up if it doesn't see an input signal. Try the game on another set. Problem may be with the game.
Toshiba CF35F50... | Answered on Mar 10, 2010
hi, is problably your turner its damage
Toshiba CF35F50... | Answered on Jul 09, 2008
Bad connections in tuner. If your really careful, lots of very small parts, you can resolder the cracked solder ground connections to the metal box and metal shields.
Toshiba CF35F50... | Answered on Nov 04, 2007
Since it is 9 years model definetely loose contact and flux corrosion is there in wire connector and pcb also. Make one general service. Prolem solved.
Toshiba CF35F50... | Answered on Aug 23, 2007
You are missing the red color drive or it is weak. there are adjustments for that in the service menu or on the CRT drive board, but you should not attempt these adjustments unless you have a service manual or know 100% what your doing and how to do them. it could be the picture tube is weak or there could be a problem in the RGB drive circuits. Depending on how old the set is should determine or not it would be worth dropping any cash into it Good Luck
Toshiba CF35F50... | Answered on Mar 20, 2007
The set needs service ,I dont think a new set is the answer a qualified tech should find the problem fast and inexpensibly.Get an estimate.
Toshiba CF35F50... | Answered on Sep 12, 2006
How old is the TV? Does it have a marketplace of apps that came preloaded? Is there a search button in that screen? If so search for the app, you can also search for Amazon prime Video App that comes with Hulu.
Toshiba... | Answered on Feb 23, 2021
The CT877 remote was included with several Toshiba TVs, including the 26DF56. Thus the programming codes for the remote are in the TV manual on pages 16-17. This manual is available on the support page: https://support.dynabook.com/support/staticContentDetail?contentId=2844172&isFromTOCLink=false . The current link to the manual is https://content.us.dynabook.com/content/support/manuals/userguides/su2844172/xxdf56_om_e.pdf . It does not have any codes to control other TVs.
A universal remote that was programmed six months after your Spectre TV was manufactured would probably be a better solution for you. I hope this helps.
Toshiba... | Answered on Jan 23, 2021
I think you need to contact there customer support or read the manual.
Visit https://www.frogbridgedaycamp.com/
This sounds like a problem either with your internet/network connection or Netflix. i would recommend a few steps to isolate where the problem is:
Step 1. Use another device, e.g. tablet, pc or laptop on the same network as your Blueray device/WII and see if you can connect to Netflix.
** If you cannot connect to Netflix, go to step 2.
** If you can connect, Netflix is fine, the issue is with the connection between your router/modem and the Bluray/WII console. Go to step 2.
Step 2. Take your laptop/ tablet and connect to another network, a friends or neighbors, or a hotspot from your phone. Then try to connect to Netflix.
** If you are able to connect and watch Netflix, the issue is with your network. Go to step 3
If you are unable to connect to Netflix, you may have a problem with your account. Contact Netflix support, who are normally very good at trouble shooting the problem.
Step 3.
** On the Bluray and Wii, disconnect from the network and forget this network.
** Next power off your modem and router, wait 10 minutes and power them back up again, modem first, then the router.
** Once all the right light are steady on both the modem and router, try to connect either the Bluray or Wii to the network and see if you can get Netflix to work. If yes, you are in luck! If no, you may need help from an internet professional or the 1-800 support line of your router manufacturer.
Hope that helps.
Toshiba... | Answered on Jan 21, 2021
Televison & Video Logo
Popular Tags
14 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba cf35f50
  • Televison & Video
