20 Most Recent Toshiba CF35E50 35" TV Questions & Answers
The sound processing section circuits ahs the fault. It is a skilled work. You have to downlaod the repair book to your Toshiba to get more details about the fault.
Toshiba CF35E50... • Answered on Apr 29, 2012
Sound like cold solder joints on the vertical output ic. The vertical output ic is usually a inline 7-9 pin chip that begins with la prefix. Not hard to repair at all just be careful not to touch anywhere near the anode leads to the picture! Basically it will knock the **** out of you. lol..
Toshiba CF35E50... • Answered on Oct 21, 2010
schmeky, sounds like your closed captioning is turned on, go into the menu and it will say "CC" or closed captions, and set it to off mode, end of problem, Happy Holidays.
Toshiba CF35E50... • Answered on Dec 01, 2007
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Toshiba CF35E50... • Answered on Mar 23, 2007
Sounds like some thing short circuit at its circuit board. Short circuit protection activates, as the set is switched on. Contact any service technician to check and find out the fault. This is not a user repairable fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Toshiba... • Answered on Mar 06, 2021
How old is the TV? Does it have a marketplace of apps that came preloaded? Is there a search button in that screen? If so search for the app, you can also search for Amazon prime Video App that comes with Hulu.
Toshiba... • Answered on Feb 23, 2021
The CT877 remote was included with several Toshiba TVs, including the 26DF56. Thus the programming codes for the remote are in the TV manual on pages 16-17. This manual is available on the support page: https://support.dynabook.com/support/staticContentDetail?contentId=2844172&isFromTOCLink=false . The current link to the manual is https://content.us.dynabook.com/content/support/manuals/userguides/su2844172/xxdf56_om_e.pdf . It does not have any codes to control other TVs. A universal remote that was programmed six months after your Spectre TV was manufactured would probably be a better solution for you. I hope this helps. Cindy Wells
Toshiba... • Answered on Jan 23, 2021
I think you need to contact there customer support or read the manual.Visit https://www.frogbridgedaycamp.com/
This sounds like a problem either with your internet/network connection or Netflix. i would recommend a few steps to isolate where the problem is: Step 1. Use another device, e.g. tablet, pc or laptop on the same network as your Blueray device/WII and see if you can connect to Netflix. ** If you cannot connect to Netflix, go to step 2. ** If you can connect, Netflix is fine, the issue is with the connection between your router/modem and the Bluray/WII console. Go to step 2. Step 2. Take your laptop/ tablet and connect to another network, a friends or neighbors, or a hotspot from your phone. Then try to connect to Netflix. ** If you are able to connect and watch Netflix, the issue is with your network. Go to step 3 If you are unable to connect to Netflix, you may have a problem with your account. Contact Netflix support, who are normally very good at trouble shooting the problem. Step 3. ** On the Bluray and Wii, disconnect from the network and forget this network. ** Next power off your modem and router, wait 10 minutes and power them back up again, modem first, then the router. ** Once all the right light are steady on both the modem and router, try to connect either the Bluray or Wii to the network and see if you can get Netflix to work. If yes, you are in luck! If no, you may need help from an internet professional or the 1-800 support line of your router manufacturer. Hope that helps.
Toshiba... • Answered on Jan 21, 2021
It will only need setting up if the EEPROM has been changed and in that case follow the service instructions. Otherwise the main menu will give aspect ration and tuning adjustments.
Toshiba... • Answered on Jan 13, 2021
Televison & Video Logo
9 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
black square covers 80 screen most
  • Televison & Video
