20 Most Recent
Aficionado C123 Built-In Drawer Refrigerator Questions & Answers
What does a EE error code mean
This is most likely a sensor problem, unplugging your refrigerator for 1 minute and plugging it back should reset the board and clear this error code.
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
- Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
- Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
- Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
- Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
How do I replace the boards in n'finity pro hdx 77-bottle wine refrigerator. Model BU-270D-A1
Remove all bottles and shelves from the unit.
Unplug the power cord from the outlet and wait for the unit to cool down completely.
Locate the screws that secure the boards to the back wall of the unit and remove them with a screwdriver.
Carefully pull out the boards and disconnect any wires or connectors attached to them.
Replace the boards with new ones and reconnect any wires or connectors.
Secure the boards to the back wall with the screws and tighten them firmly.
Plug the power cord back into the outlet and turn on the unit.
Reinstall the shelves and bottles and adjust the temperature settings as desired.
Gas charge amount for Mishto 55lt car fridge ?
The amount of coolant is included on the compressor label.
Once reading the label, perform a vacuum test for 15 minutes and if it holds with no leaks, refil to the correct weight of coolant and seal.
What level should i put my kic fridge to turn off automatically?.
A 'kic fridge'???
You mean turn off automatically on a thermostat? The dial should always be around halfway, so 4 to 5 on a scale of 9. A thermometer in the fridge should show 3' to 5'C on an open middle shelf.
Please include 'make model (what it is)' in all questions first 3 words.
