20 Most Recent
Toshiba 61A60 TV Questions & Answers
Sound card
Contact the nearest authorized service center for Toshiba at your town.
How can i reset the toshiba 61A60
Disconnect the AC power
for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of
the unit.
Press and hold the Volume down button on the front of the unit and the 0 button
on the remote control at the same time, holding them down for at least 10
seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will
appear.
Enter your new password.The V-Chip is bypassed by
holding the zero key on the original remote hand unit, and at the sane time
holding down the volume down on the front of the TV set. This should reset the
oide so you can enter a new one.
I gotta a green screen
It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
We have a 42
Make sure the speakers are turned on. Somewhere in the audio setup menu there should be a switch for the speakers. Make sure there is not one on the back of the set as well.
Service mood
most models of tosh projo tv service MODE is mute on remote hold that down whilst pressing menu on tv letgo both press menu again
you get an s
use channel up or down and vol up dn to scroll/adjust
enter 7 on remote to enter convergence fine tune.
Picture looks dirty in corners
hi there, maybe you do have some speaker, transformer or any magnetic near the unit that magnetise the screen. remove any magnetic matterials near the screen and it will come back normally. the cleanning is behined only the screen by brush. ty
61a60 Toshiba Flyback
Have you check the HOT Q404?
I would suggest to check that transistor before you decide to replace the flyback. The way to know if you are getting high voltage would be to pay attention for like a charging/discharging static noise when you press the power button to turn the TV ON or OFF.
Let me know if you require further assistance.
Toshiba 52 in tv
Most likely = bad Hyper board....need exact model # off back
of set for more info..................T.
Broken screen
Yes, try contacting a toshiba parts dealer. The process of changing the screen is not simple but it is not impossible.
Try to get the service manual first so you can see what is involved. I suggest going to getmanual.com and spending $5-10 to download the PDF service manual.
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
Toshiba 47" flatscreen. Power up
The information provided suggests that there might be an issue with the main board of the electronic device. However, it's important to consider a few factors before deciding to replace the main board:
- Check for Error Codes or Diagnostic Signals: Some devices have error codes or diagnostic signals that can provide more specific information about the issue. Check the device's manual or documentation for any error codes or signals associated with the flashing LED or other symptoms.
- Perform a Hard Reset: Before replacing any components, try performing a hard reset on the device. This involves turning off the power, unplugging the device, and waiting for a few minutes before plugging it back in and turning it on. Sometimes, this can resolve temporary glitches.
- Consult Manufacturer Support: Contact the manufacturer's customer support or refer to the product's support resources. They may be able to provide troubleshooting steps specific to your device and guide you on whether a main board replacement is necessary.
- Professional Inspection: If you are not familiar with electronic repairs, consider consulting a professional technician. They can inspect the device, run diagnostics, and provide a more accurate assessment of the issue.
- Check Warranty: If the device is still under warranty, replacing components yourself may void the warranty. Check the warranty terms and conditions before attempting any repairs.
- Consider Other Factors: The issue might not solely be with the main board. Power supply issues, faulty connectors, or other components could contribute to the problem. A thorough inspection can help identify the root cause.
If, after considering these factors, you still believe that the main board is the likely culprit and you are comfortable with the replacement process, you can proceed with replacing it. However, exercising caution and exploring all available troubleshooting options is advisable before making any decisions.
1/17/2024 8:35:42 PM •
Toshiba...
Answered
on Jan 17, 2024
