20 Most Recent Toshiba CZ36V51 36" TV Questions & Answers
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many popular TVs are given in detail.
Toshiba CZ36V51... | Answered on Oct 19, 2013
It depends on who looks at the set and what they find---36 inch set with soldering issues anything from 50 dollars on up..........
Toshiba CZ36V51... | Answered on Dec 04, 2012
hello donna!
looks like tv's picture tube is worn out. the tube is not focusing well anymore. changing picture tube is not common, because it is very expensive and i dont know either to get even one as spare part.
But a local service person can try to re-focus (adjust Flybacktransformator). this helps often to get better sharpness results. so might give you some more years to use it well.
PLEASE dont try to adjust by yourself - HIGH VOLTAGE - mortal danger!
hope to helped a bit - for any further help dont hesitate to contact me here under your topic.
regards
Toshiba CZ36V51... | Answered on Feb 20, 2011
you need to take the back off unplug all cables (mark were they go back) take of the fly back cable (top of tube) by lifting the rubber crimp the strike pins pull of. the take out circuit board and there at the front will be the ir sensor desolder it and replace with new one
good luck
let me know how you go
Toshiba CZ36V51... | Answered on Dec 29, 2010
Sounds like you have a horizontal timing error causing the mirrored image. It is fixable but would require the main board to be replaced. The part number is 23783078 but appears to be no longer available.
Toshiba CZ36V51... | Answered on Aug 28, 2010
Hi:
This is likely due to a bad flyback transformer on the deflection power supply board, when changing this part also replace the horizontal output transistor as these two parts work in conjunction with each other.
Toshiba CZ36V51... | Answered on Jun 12, 2010
don't wory sir , may i help you .
this is a not mager problum but sum times technicean is parsnal baneefits besness and fast money making this rongh dignosis and canfused to castamer so don't wory ...
[1] problum is in side tv set in out put voltage form EHT becose your tv is red and green light is ok then SMPS is ok
pls. check with tv techicean and follow sum tips
* voltage check From EHT out put and canacting spear.
* H- out put tangester and cancting sperar
* H out put tarngester base tarminal voltage check if ok then 100% problum is EHT or canacting spaer so don't wory all spear is not very expancive pls.find Best tech.and solve this problum Esely
best of luck...
Toshiba CZ36V51... | Answered on Jan 31, 2010
Sounds like you have a "Dry Joint" or bad connection, or even a faulty power switch.. this is a fairly common one... try a switch replacement first? Or look for a bad joint on or around the switch connections.
Toshiba CZ36V51... | Answered on Jan 30, 2010
There is a part insidethe TV that needs to be replaced; probably the main board. If the TV is under warranty—whetherthe original warranty from the manufacture or an extended warrantypurchased with the TV—call the company providing the warrantycoverage and they will arrange to have your TV repaired at little, orno cost to you.
If the TV is out ofwarranty, and you have the experience and you know what you're doing,you can fix the TV yourself. Purchase the service manual from themanufacture to get started. However, if you've never done anythinglike this type of repair before and you don't know where to start, Isuggest speaking with an experienced TV repair-person.
If you decide to pay forout of warranty repair by a professional repair shop, the total costwill likely be a minimum of $300 parts and labor. However, be warnedthat the cost could be considerably higher. A new 37" LCD from Walmart.com would cost you $468.
Since some brands willpay for your repair even if you're out of warranty, you shouldcontact the manufacture first for your full range of options. Ifthey're willing to fix the TV for free, let them!
I hope I've provided youuseful assistance and that this information allows you to make aninformed decision as to how to proceed from here. Please be sure tovote on my response. I hope I've earned a good rating from you today!
Please post a comment ifyou need additional assistance so that I can help you further.
Toshiba CZ36V51... | Answered on Jan 10, 2010
Try unpluging the television for about fifteen minutes
Toshiba CZ36V51... | Answered on Nov 20, 2009
Hi
Thanks for using FixYa. First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent picture tube issue, a bad driver transistor on the CRT board, a bad connection on the crt board, or a problem in the RGB coming from the video jungle IC. As the TV is quite old, the repairs will cost you around $200-250.
Note-- If you are doing these repairs yourself then please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Try to reset the TV by unplugging it for 8-10 hours.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Toshiba CZ36V51... | Answered on Nov 01, 2009
Sounds like a cold solder joint somewhere.
Toshiba CZ36V51... | Answered on Oct 17, 2009
sounds like a bad flyback transformer p/n 23236492 .but you would need to know how to solder . and crt safty. no reset that i know of with that symtom.
Toshiba CZ36V51... | Answered on Sep 28, 2009
Either the CRT Drive Board is bad or the CRT is shorted.
Toshiba CZ36V51... | Answered on Jul 25, 2009
check your horonital output transistor could be defective.
Toshiba CZ36V51... | Answered on May 13, 2009
I do not have that make and model. However:
Some remotes have to have a code set that matches the brand of the tv. Your remote should have come with a list of brands and codes.
Alternatively, the instructions for your remote should tell you how to determine which code to use.
Toshiba CZ36V51... | Answered on Mar 20, 2009
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Toshiba CZ36V51... | Answered on Dec 31, 2008
sir, if you are not a technical person what i mean does not really repair like this equipmetns then it will not be easy for you to repair this. but ill give you an idea of what's wrong with your TV. Just cold solder or loosened solder on the vertical amplfier section. But if you can handle soldering and also dismantling the main board then you can just try to find the vertical amp section and look at those solders of parts around for loosened welds. just resolder it. be careful not to short any part or it cause major trouble and make your problem bigger. For a technical person, this trouble is a simple one.
Toshiba CZ36V51... | Answered on Oct 18, 2008
Toshiba CZ36V51 36" TV Logo
Popular Tags
30 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
cz36v51 36 tv about week picture
  • Televison & Video
